diffuse light scene
own1221
it looks like there's a secondary light source to the right out of view that's giving the nice even light. the version you've made seems like it's in a solid box with just that light slit to provide all the light for the room. I'd up the secondary bounces, increase the exposure time, or add that second window into the room. Just my 2 cents
New test render, I dont know why the bottom left corner of the wall is really dark but the floor is ultra bright?
hi own1221,
i'll test the file later.
i don't know how max handles material's properties, but can you control the value of reflected lighting ?(diffuse?)
can you assign a diffuse illumination model such as blinn, oren-nayar, or phong?
if you can you should be able to have access to sliders that control the diffuse & fall-off amount.
what kind of lighting are you using?
if you fake the lighting, using lights above the openings,
i think that they should attenuate using inverse-square law.
With max you can change how much light is reflected by how dark the diffuse map is, the floor bitmap isnt that much lighter so shouldnt be that bright, it could be the angle of the light though which points more down than towards the wall.
With the lighting I'm using vray plane lights (large rectangular lights) for the top opening, and window infront and also another on the right of the camera and behind to simulate two other windows.
Please do try out the scene the guy who did the original image used cinema4d too.
