femmyextra Posted February 22, 2008 Share Posted February 22, 2008 Hello every one. I am new to cgarchitec.com but i believe i can get help from here. I tried rendering the model shown below using 3ds max mental ray. (mr sun), when I turn on Final gather and GI, Max keeps crashing..... pls hlp with tips and settings to make the redering come out good. Im using a Qaud duo with a 4gig ram Link to comment Share on other sites More sharing options...
frank1331 Posted February 22, 2008 Share Posted February 22, 2008 Looks like you have exported this from AutoCAD or Revit, which can bring in a lot of unnecessary things. This pushes the poly count very high. Also the trees look pretty high res. Try rendering it without the trees and at a lower resolution to try and pin point your problems. Link to comment Share on other sites More sharing options...
muchhal.sandeep@gmail.com Posted February 25, 2008 Share Posted February 25, 2008 HI, It seems to me as if you are taking the still from eye level below ground . No issued. increase the memory limit from 650 to 3072 if it is a 32 bit OS. and make the glass properly as you go in real glass with transparency and reflection it kills your computer. try to have some solution i.e. try relecting a bitmap. remove those trees if possible they are a huge memory occpier. rest will be fine I hope. Link to comment Share on other sites More sharing options...
