panorama exporter
muchhal.sandeep@gmail.com
Hi all,
I am currently working on a interior scene and planning to give my client a panorama :)
issue is when i render it through pnorama exporter of max i get ouput on a very low resolution
I am doing it on mental ray and max.
it seems to be of a very low size and is really blurry :mad: :mad:
m in a trouble since i have already taken advance for it.
guys help out please.
I had the same problem recently but I am using v-ray. Same difference though. My solution was to render out a equirectangluar spherical map at something like 5000x2500 pixels and import that render in a software like pano2VR or similar. Worked like a charm.
Use a standard camera because I know the v-ray cam doesn't work. Set you render output size to 5000x2500 (2:1 ratio). You can go bigger if you can. Then set the camera overide to spherical and set FOV of 360 and render out as you normally would. The resulting image will look kinda weird and distorted but don't worry about that. Then import that render in pano2VR, it very easy to use. They have a watermarked trial but it's cheap for a single license (100$ or so).
I hope you get out of that mess you're in lol
  • 1 year later...
  • 2 weeks later...
