need your comments
nodar1978
Did you post these in another thread? There's something strange about them, maybe it's just the design... the upholstery is very busy, the cabinet is very antiqued and then the floor has a very perfect reflection. Also the quality of the objects isn't that high - the piano is visibly faceted and the rug is blurry, like it's got a low res map, and there's just something not real about the cabinet. It keeps drawing my eye back to it. The chandeliers look like photos with a slightly off alpha map, they're not reflecting right and the perspective isn't right when they're in the floreground.
Sorry if this is sounding all negative, when I look at the actual building which is probably the part you've modeled yourself it looks good - just work on those reflectivities - but the space is so full of this stuff that's a couple notches away on the realism scale that it's distracting. If you're working for an interior desecrator who's only interested in getting as close as possible to the "design" (in the sense that design can mean furniture shopping), I sympathize, because there's not much to be done with that sort.
hello Andrew
thanks for comments. yes I work for interior designer, it's a hotel design in classical style in Holland. And she needs this visual to show clients and discuss the furniture, and have a just views of room, and have an idea how big should be fireplace.
will be great if designer will not ask me change anything :) because I've spend too much time for renderings in radiosity. there are too much objects, and i render it layer by layer, and then I made montage in Photoshop, that’s why lamps does not looks nice.
thank you again
