beginner needs help - exterior
Arnodelange
Hi I’m Arno. Normally I work with Revit architecture. But I’m always been fooling around with 3d max. The time has come to make the big jump and make some real nice pictures with 3d max. I use MR in max, because this render engine will also be used in Revit 2009.
Oke...this is my first real try at some thing. I need some help on the following topics.
- Sky : I use Mr. physical sky in the environment map, with a jpeg in the
haze RGB level at 8, but I can't get clear skies
- grass: I did the tutorial of .... need to verify...will be back on this one
need to change the colour of the meadow in the background. there is
a ditch between the two planes with some high grass (grass-o-
matic), but you can't see it with this quality.
- pavement: I want to add some grass between the tiles and some gum on
the ground. What is the best way to do this?
- glass: need to change the glass, but haven't done researche one this, so
will try this myself
if I need to submit some settings please let me know
Other C&C are more than welcome.
Arno
Welcome Arno,
I don't know mr......but from a visual stand point.
The colors are wild. They need to be adjusted.
I would also adjust the camera a bit. lower it a bit...zoom in a little..imo
Good try for your first go....I LOVE THE COWS in the bg.....nice touch. Looking forward to the progress.
