how to achieve this effect
chow choppe
i think, if you look close, you'll find that the floor material is a different material to the material applied to the rest of the scene.
so apply vray edgetex material to the chairs / table and create a material with reflection and bump for the floor then render.
BTW, you can add reflection / bump etc. to the edgetex material just as you would a normal material.
"i dont think thats the trick..."
You won't get one of these...
Main Entry: tu·to·ri·al
Pronunciation: tü-ˈtȯr-ē-əl
Function: noun
Date: 1923
: a class conducted by a tutor for one student or a small number of students
on one of these...
Main Entry: fo·rum
Pronunciation: ˈfȯr-əm
Function: noun
Etymology: Latin; akin to Latin foris outside, fores door — more at door
Date: 15th century
: a public meeting or lecture involving audience discussion
though you can always ask for one of these...
Main Entry: cri·tique
Pronunciation:krə-ˈtēk
Function: noun
Etymology: alteration of critic
Date: 1710
: a critical estimate or discussion
and...
Main Entry: ad·vice
Pronunciation: əd-ˈvīs\
Function: noun
Etymology: Middle English avis, advis view, opinion, from Anglo-French, from the Old French phrase ce m'est a vis that appears to me, part translation of Latin mihi visum est it seemed so to me, I decided
Date: 14th century
: recommendation regarding a decision or course of conduct
which you can either...
Main Entry: ac·cept
Pronunciation: ik-ˈsept, ak- also ek-
Function: verb
Etymology: Middle English, from Anglo-French accepter, from Latin acceptare, frequentative of accipere to receive, from ad- + capere to take — more at heave
Date: 14th century
: to receive willingly
: to endure without protest or reaction
or if you choose...
Main Entry: dis·miss
Pronunciation: dis-ˈmis
Function: transitive verb
Etymology: Middle English, modification of Latin dimissus, past participle of dimittere, from dis- + mittere to send
Date: 15th century
: to reject serious consideration of
but doing this...
Main Entry: con·tend
Pronunciation: kən-ˈtend\
Function: verb
Etymology: Middle English, from Anglo-French or Latin; Anglo-French contendre, from Latin contendere, from com- + tendere to stretch
Date: 15th century
: to strive or vie in contest or rivalry or against difficulties
: to strive in debate
: argue
will get you nowhere. :)
Function: noun
Date: 1923
on one of these...
Main Entry: fo·rum
Function: noun
Date: 15th century
Function: noun
Date: 1710
and...
Main Entry: ad·vice
Function: noun
Date: 14th century
Main Entry: ac·cept
Function: verb
Date: 14th century
or if you choose...
Date: 15th century
but doing this...
Function: verb
Date: 15th century
: argue
Hilarious............!
thanks shane for the encouraging words
i am sure u dont know the right answer for that question and maybe trying to increase the number of posts and becoming junior member and then senior member and then veteran but actually the posts doesnt have the right content.
I would not rather answer than to discourage someone. every person has a way to ask questions . mine is not similar to yours so please keep your vocabulary or google searches with you if you dont know the right answer.
No offence
thanks
"...No offence"
Fair enough, my apologies and no offence taken.
If I were trying to recreate the image (bear with me - I use Maya) I'd create the model, assign the geometry to two render layers, assign an opaque wireframe material to all the geometry except the curtains, a second translucent wire material to the curtains in the "top" layer and then apply the lambertian/ blinn type shaders to the "bottom" layer. Make your "wire frame" geometry invisible to the camera in the bottom layer, but ensure it casts shadows. I'd then set up my final lighting - breaking some light linking here and there (glass brick-type window for example), make my final render settings per layer (make sure to match your AA and filters), and render. Take the output renders into Photoshop and comp top over bottom. If you wanted to be extra tricky, you could render a separate pass which included the wireframe texture in the reflection in the mirror (to the right of the image) which the original render you posted does not contain.
Hope this helps,
S.
