cullen Posted February 26, 2008 Share Posted February 26, 2008 I am seriously going crazy here. I've got a file that I have been trying to render for 2 days. It will reach different points of the rendering process then completely close max. I don't get any error messages or anything. I have stepped back through the model several times deleting pieces trying to find out what the problem is. Below are my rendering settings. Polys: 1,961,833 Vray Sun Image sampler: Adaptive DMC Inderect illumination: Primary bounce: 1.0 Irradiance map Secondary Bounce: 1.0 Light cache Irradiance map: very low Light Cache: subdivs: 1000 Sample size: .02 Scale: Screen Passes: 2 Store direct light: yes Show calc. phase: yes Pre-filter: no filter: Nearest Samples: 10 Any help on this would be greatly appreciated. Link to comment Share on other sites More sharing options...
BrianKitts Posted February 26, 2008 Share Posted February 26, 2008 render with your task manager open and watch your ram count... biggest cause of a vray crashing is running out of ram, so if you hit 0 and max closes then you'll know why. which will basically mean it's time to start using the vray proxy and vrimg to make better use of your system resources. Link to comment Share on other sites More sharing options...
cullen Posted February 26, 2008 Author Share Posted February 26, 2008 Thanks for the tip Brian, I actually tried this already and generally have about 1.5gb still available when it crashes. Below are my system specs. Core2 Quad @ 2.40GHz 4GB RAM MAX 2008 V-Ray Adv 1.5 SP1 I should also mention that I am using Onyx Trees in my model. Link to comment Share on other sites More sharing options...
smr_VIZ Posted February 26, 2008 Share Posted February 26, 2008 one time, I changed my second bounce to another type. And it didn't crash anymore. Not sure if it is your case, but just want to share my 2 cents. Link to comment Share on other sites More sharing options...
cullen Posted February 26, 2008 Author Share Posted February 26, 2008 Thanks James. I've actually tried serveral different configs for the bounces. I decided to remove all of my grass (vray fur) and it seems to be going further than it has in the last 2 days. It would figure the main thing the client wants is whats crashing it. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 26, 2008 Share Posted February 26, 2008 What resolution are you rendering? Are you using proxies for the trees? Link to comment Share on other sites More sharing options...
cullen Posted February 26, 2008 Author Share Posted February 26, 2008 Currently I'm trying to render @ 490x270. My final will need to be much larger. I have 16 trees in the model. These trees are not using proxies but they are different variations. It seems to be something wrong with the VRayFur. When i completely deleted them from the scene the rendering completed in less than 5 min. Does anyone have any tips for optimizing the VRayFur for grass? Thanks. Link to comment Share on other sites More sharing options...
Billabong Posted February 26, 2008 Share Posted February 26, 2008 This happens to me sometimes to, but it done it in max 9 as well,when I was using it. I think its just a max bug and doesn't have anything to do with vray, but I'm just speculating Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 27, 2008 Share Posted February 27, 2008 Pay attention to the amount of fur you have. I've seen people use distribution "per area" set to something like 20 (the default is 0.2) and experience constant crashes. Keep in mind that the more fur you have, the heavier and more unstable the scene will get. Link to comment Share on other sites More sharing options...
cullen Posted February 27, 2008 Author Share Posted February 27, 2008 The fur was the problem. I was one of those people... I had 3 planes each with the distribution around 30. I've switched it to displacement and it seems to be working now. I'll have to see what happens once I go big though. Thanks for the help everyone! Link to comment Share on other sites More sharing options...
