help with Environment picture
iceman478
drag the map from your environment slot into the material editor. Inside the map's parameters you can adjust the "offset" and other attributes which will allow you to change it's position.
If I'm inserting my background in max I normally just map it on a plane and place the plane properly in the scene.... makes it easier to adjust.
