robkar97 Posted February 28, 2008 Share Posted February 28, 2008 I'm doing a lawn made from Hair and fur, and to speed things up I would like to disable shadow casting for the grass and only make the grass receive shadows from other objects. Going to the growth object's properties and unchecking Receive shadows doesn't help... is there another way of disabling shadows? I'm lighting the exterior scene with a daylight system, so I can't use Exclude for the sun (?) Robert Link to comment Share on other sites More sharing options...
xeunox Posted February 28, 2008 Share Posted February 28, 2008 sellect the grass object, right click>object properties switch off cast shadows there Link to comment Share on other sites More sharing options...
robkar97 Posted February 28, 2008 Author Share Posted February 28, 2008 That's the problem... it doesn't work :-( I think it does when using "buffer" hairs, but not for "mr prim"... Only the growth object (a simple plane) stops casting shadows. Similarly, turning off Renderable for the growth object leaves the hair unaffected (it still renders) Link to comment Share on other sites More sharing options...
