how to model arches in curved plans
chow choppe
Hi
we have been using acad to model 3ds but now we are trying to learn it the 3dsmax way
Facing a problem modelling a building and its details because the plan is in curve form and also the elevation has arches. Arches have mouldings also. So its kind of difficult to understand how to model that. i am attaching the plans and elevations of the buildings. the building is simple with just arches in the verandahs but how to model those arches accurately in a curved wall is our problem.
also i attached an image to show the details we will have to model in the building
Please tell us how to model these. we have the cad files with us . But they have filled everything with hatches so they have become very heavy to navigate
thanks
This is one of the most difficult ones i have seen. Normally one would be able to do it in sections and use the plan to radial offset or array, but the elevations vary. I would normally do a section of a cylinder and then shapemerge an arch spline onto that, convert to poly and delete unwanted faces then add shell modifier for thickness. After this you would collapse to editable poly again ,select bottom faces and extrude down, bevel etc. for the moulding. Then you would copy rotate all your segments of verandah arches using the supplied radius
none of this would be super accurate though.
It would be very complicated to build as well.
the elavtions are the projected elevations of the curve and doesnt depict the true length of the wall
So how can we places arches accurately in that
how do we know that what distance apart arches should be placed so that when we bend the wall the arches come at exact locations and are accurate in size
Thnks
Thnks
Surely you can deduce from the top view the proper location of the arches? Those "eleveations" look suspiciously inaccurate to me any way, as if they were hand-drawn, pretty much.
Remember max modelling is non-destructive; you can make a boolean of a hole in a wall, then apply bend, then go down in the stack and move around a component of the boolean operation to line up, say, an arch over it's counterpart in the plan view. (Have the "show end result" thing checked in on the modifier panel)
/Z
can i go back after making boolean operation
i doubt it
Of course you can:
Make a box
Make a sphere
Move sphere so it intersect box somehow
Select the box
Create new object, "Compound Object" -> "ProBoolean"
Click the "Start Picking" and pick the sphere
You should now have a "box with sphere shaped hole in it"
Go to Modify panel
Expand the ProBoolean ("+" in modifier stack)
Select "Operands"
Now further down in the modify panel you'll see "Box" and "Sphere"
Select "Sphere" there
Notice how the gizmo moves to sphere center?
Select "Move" tool. Move the sphere. You will see your "spherical shaped hole" move (if you have "show end result" turned on)
You can cut out all the arches you need, then bend the whole thing. (Tip: Tell ProBoolean NOT to remove edges ("Advanced Options" rollout), or your boolean object won't "bend" well)
/Z
i would make a arc in plan on outer side of the wall
then refine it to add points on the depicting the width of the window
then extrude it
convert it to poly
then connect edges to get the cill lvl of windows for upper arches i would make a arch in front view then use shape merge to add the curve
then u can use extrude polygons to make rest of the things
then u can use shell modifier to add thickness to wall
i hope it will help
then extrude it
convert it to poly
i hope it will help
ishpal i hope array will also be used after that after making the centre most arch
thanks xeunox for the lovely effort
i really appreciate the fact that u took time to make a tutorial
But the tutorial is for a arch whic is in a straight wall
my wall is curved in plan?
can u make one with a series of arches in a curved wall
thanks
I don't use Max, but in both SketchUp and LightWave this shouldbepretty straight forward? In LW I would use Rail Extrude to make the mouldings.
I had to wait for somenew plans here, and spent half an hour in SketchUp doing some tests, as on the attached image.
I made components of each segment, 6 degrees "slices", and used an arch and booleans to cut the outer face. Then I made a profile and used FollowMe to extrude it along that curve.
Surely there must be some similar tools in Max?
I did some tests over the weekend to try and figure something out. The most accurate way I could find to model the curved arches was bu using spline cages and patches, but it was a real time consuming pain using that method. The easiest, and fastest way I could find was to poly model the arches... I used the Bridge tool (in edit poly) and bridged the polygons on my columns to form a flat, straight beam, then I turned up the subdivs for the bridge, and just moved edges and vertices's to fit my plan.. After the first couple I did, I mad the process down so it only took a couple seconds to do one. The drawback is that since this method uses polygons, rather than splines, the quality of the result is dependent on how many subdivs you use for the arch, and of course the more polys your moving around, the longer it takes.
-Nick
A week ago, a had a fancy curved bridge to model, I spent a half a day, finding a good solution to make it accurate, than I realised, that the only way to do it accurate is NURBS modeling, so I gave up, started it up with one simple box, made few elements for booleans and that took me about 30-45mins to complete.
So do it easier way, boolean, than add a edit poly mod, to make the splines for windows frames, glass as shell mod...
Good luck!
