gateway quad core any good?
guys i am looking for a new machine to do my 3d work on and i cam across a refurbished gateway with some impressive specs for 600 bucks. How do you guys feel about gateways are thay any good. I always worked on a dual xenon dell orecesion 470 with 4 gb of ram i really dont want to go backwards by switching to this machine. here are the specs.
Specifications: Processor:Intel® Core™ 2 Q6600 quad core processor
Each core operates at 2.40 GHz
2 x 4MB L2 cache
1066 MHz front side bus
Operating System:Microsoft Vista Home PremiumChipset:Intel G33 Memory:Installed: 3072 MB DDR2, 667 MHz, (PC2-5300) dual channel memory (two 1024 MB and two 512 MB modules)
Expandable to: 8 GB (4 DDR2 DIMM slots)
Hard Drive:500 GB, 7200 RPM, SATA II hard drive
Support for up to two hard drives
Optical Drive:DVD ±RW, 18X multi-format dual layer drive (up to 8.5GB)
Write max: 18X DVD±R, 8X DVD+R DL, 8X DVD-R DL, 8X DVD+RW, 6X DVD-RW, 12X DVD-RAM, 48X CD-R, 32X CD-RW
Read max: 16X DVD-ROM, 48X CD-ROM
Supports Labelflash™ on disc printing (req. Labelflash media)
Power Supply:Voltage Required: AC 120/230 V
Power provided: 400 Watt
Media Card Reader:15-in-1 high speed card reader supporting the following:
Compact Flash (CF) I, II
IBM Microdrive™ (MD)
SmartMedia Card (SMC)
Memory Stick, Memory Stick Duo, PRO, PRO Duo
Secure Digital (SD), MiniSD
Multi Media Card (MMC), Multi Media (MMC) Plus, Mobile
RS Multi Media Card (RS-MMC) (need adapter)
xD-Picture Card (xD)
Video:NVIDIA® GeForce® 8500GT
256MB onboard video memory
DirectX® 10, BluRay/HD-DVD Capable
VGA Port
DVI-I with HDCP Port
S-Video Port
Audio:Integrated 8-Channel (7.1) High Definition AudioNetwork Support:Integrated Intel 10/100 Mbps Ethernet LANModem:56K ITU V.92 ready Fax/Modem with RJ-11 portAdd-in Card Slots:One PCI Express ×16 (graphics interface)
Two PCI Express ×1
One PCI conventional
External Connectors:One PS/2 keyboard port
One PS/2 mouse port
One VGA monitor port
Eight USB ports (six rear, two front)
Two IEEE 1394a port (one rear, one front)
One RJ-45 Ethernet LAN port
Seven audio jacks (five rear, two front)
One S/PDIF optical audio port
Drive Bays:Five Total:
Two external 5.25-inch
One external 3.5-inch (with a docking bay for optional Gateway 2.5-inch removable USB hard drive)
Two internal 3.5-inch (hard drive)
Physical Dimensions (H × W × D):15.6 × 7.2 × 16.1 inchesWeight (Unpackaged):Minimum 23.4 lbs. (varies with configuration)BIOS revision :DPP3510J.15A.0296
They made a lot of decisions I wouldn't, but my CPU, MB and RAM would add up to more than their entire computer costs.
Unless your Dell is pretty new and has Core2-type Xeons, this machine will be faster. I have no idea whether a Geforce 8500 is any good but you can swap that out later and still be saving money.
For $600, its a deal. Forget the brand.
Maybe try haggling a little, get them to put in an extra gig in exchange for the worst graphics card they have (instead of the 8500) then hook it up to your machine as a render node.
get them to put in a cooler for the processor as well. Nothing fancy, just something quiet.
