Ray1618 Posted March 4, 2008 Share Posted March 4, 2008 hello, I've made a 3d model and now I'm buzzy on the mapping, but I got a problem with the bricks. It seams to be really repeating it self over and over again, anyone got a good way to prevent this from happening?!? This is how it looks like right now Link to comment Share on other sites More sharing options...
STRAT Posted March 4, 2008 Share Posted March 4, 2008 there is only one solution for brick mapping. use an on-line masonary designer - http://www.beldenbrick.com/md_page.htm Link to comment Share on other sites More sharing options...
Ray1618 Posted March 4, 2008 Author Share Posted March 4, 2008 Thnx man. Hmm that kinda sucks I hoped for some good randomized 3dmax alternative:( Link to comment Share on other sites More sharing options...
Mechadus Posted March 4, 2008 Share Posted March 4, 2008 You could probably get something like a random brick pattern by using the tiles map with some image maps inside it.. never actually tried it tho. Usually I just make larger image maps with more bricks to avoid the tiling problem. Link to comment Share on other sites More sharing options...
STRAT Posted March 4, 2008 Share Posted March 4, 2008 Thnx man. Hmm that kinda sucks I hoped for some good randomized 3dmax alternative:( the masonary designers give photoreal huge non-tiling brick maps. 100's of bricks squared if you want. It's a lot more real than what max can produce, and certainly doesn't suck i can assure you. since the advent of these brick designers the question of 'how do i do bricks?' has been obsolete for ages. Link to comment Share on other sites More sharing options...
Horhe Posted March 4, 2008 Share Posted March 4, 2008 there is only one solution for brick mapping. use an on-line masonary designer - http://www.beldenbrick.com/md_page.htm Nice one Strat, thx. I usually make maps in PS accordingly to what I need. Dont rely on Max entirely to do the seamless maps for you Link to comment Share on other sites More sharing options...
jinsley Posted March 4, 2008 Share Posted March 4, 2008 Great resource... thx very much! Link to comment Share on other sites More sharing options...
EricMLevy Posted March 4, 2008 Share Posted March 4, 2008 I have an answer to your question! In your tile map, change two parameters: In the Tiles Setup, multiply Horiz and Vert count by 4. Then in the Tiling Section (under coordinates rollout) multiply your tiling by 4. If it's still too repetitive, mutiply by 2, 3, 4, whatever it takes... Did I explain that well enough? Link to comment Share on other sites More sharing options...
alrawli Posted March 4, 2008 Share Posted March 4, 2008 Thats a great link thanks for sharing! That could have come in really usefull recently! Ive been using Bricks and Tiles which is good if you have photographs of the type of brick/stone your needing to map and saves on the Photoshop time, can be a pain in the neck having to make lots of textures. Link to comment Share on other sites More sharing options...
Ray1618 Posted March 5, 2008 Author Share Posted March 5, 2008 I have an answer to your question! In your tile map, change two parameters: In the Tiles Setup, multiply Horiz and Vert count by 4. Then in the Tiling Section (under coordinates rollout) multiply your tiling by 4. If it's still too repetitive, mutiply by 2, 3, 4, whatever it takes... Did I explain that well enough? Thankyou I'm gonna try think It'll work with your explenation well enough Also dove in the brick wall program and it's also really nice.!! Link to comment Share on other sites More sharing options...
blowback Posted March 5, 2008 Share Posted March 5, 2008 Strat, Thanks alot....awsome resource Link to comment Share on other sites More sharing options...
ramy Posted March 6, 2008 Share Posted March 6, 2008 jinsley, thanks for the Comment! Link to comment Share on other sites More sharing options...
