Leisure and shopping centre
Pit Matson
Interesting concept and presentation.
About the car lights: You should work on them a bit more. You probably will since this is WIP. Try adding some motion blur and little transparency.
Now its just a photoshop brush stoke.
If there were to be clouds here then this image should be done from a far greater distance from above, but since its NPR thats fine :) Perphaps make them more stylised ?
Looking nice.
  • 2 weeks later...
Thanks, SandmanNinja
Only I have used a shader, very simply to start drawing and painting above.
I show an illustration in which you can see the Ink-n-Paint shader :)
The first one is an unsuccessful picture, and I have to repeat it today.
There is a technical work in 3d with rhinoceros and max in the initial phase of design, but initially we prefer this type of illustrations that they do not compromise so much as the 3d.
Sometimes, I must work 3d with vray, radiosity or mental ray, but only if I do not have alternative.
I have to repeat the night one today...
Since we have one more day of time, it is possible that I arranges also the third one, which I do not like too much.
Are the colours added in post, or rendered?
I do a render with the Ink-n-Paint shader of Mental Ray, another one with radiosity or vray. And I save some renders elements (shadows, for example).
In photoshop I put on the top the Ink-n-Paint shader in multiply.
And I play a bit in photoshop with the curves and the renders elements.
It´s quick, nice and cheap :)
