Vray material render problem
TomA
When i go to render a scene i've made, i get this Vray message over and over again:
'warning: Texture 'Map #45 returned an invalid bump normal
warning: invalid bump normal'
I created the vray material from scratch, using 2 different jpeg bump textures as a composite map.
I've tried reattaching the bump maps and even editing them in photoshop, renaming them and then reattaching them, and also just blending them together in PS and then reattaching them as a single bitmap file, but still get the same message.
Am i on the right track here? any ideas?
Edited by TomA
I don't know i'll try.
Do you think it could have anything to do with the fact that a large part of the model is imported in from 3D Microstation (produced by Bentley rather than Autodesk)?
  • 1 month later...
I just wanted to add to this thread. I had the same problem in my scene. I didn't get the error on the machine that I had building the scene but once I moved the project to another machine the invalid bump normal error started to appear.
It ended up being an issue with the noise map placed in the bump slot of a water material that was applied to a vray plane. Removing the noise and applying another one has fixed it, I think.
hope this helps
