nivvu Posted March 12, 2008 Share Posted March 12, 2008 HI all, good to cme back to forums after a long time again...... i have a problem rendering an image at A0 size in vray.........this computer is an high end configuration machine and as i start render iam getting a mesage "error creating bitmap" i know tht A0 is a quite big iamge to render but the requirement is such tht i have to render it in a0 size image, even after saving a ir map at low resolution iamges size and giving to a0 its nt hapening..... and the max file has got 80lakh faces...its a big 60 storey building in kuwait so guys plese help in this mater ..bye and thanks in advance for ur solutions cheers nivas Link to comment Share on other sites More sharing options...
jophus14 Posted March 12, 2008 Share Posted March 12, 2008 I hate when this happens. There are a few solutions or work arounds. 1. Save render as a VRImg through Vray Frame Buffer and re-render. There are tons of threads regarding how to do this. 2. Zoom in on your image and copy the screen either by ScreenPrinto or a program called SnagIt. Link to comment Share on other sites More sharing options...
BrianKitts Posted March 12, 2008 Share Posted March 12, 2008 always render to a .vrimg file for excessively oversized renderings with vray. Link to comment Share on other sites More sharing options...
bijoy Posted March 13, 2008 Share Posted March 13, 2008 Hi, hmmm...i used to have this problem but i solved following some tips by someone from some forum...haha (cant remember which one). Actually it was a life save cause i couldnt even render for an A3 size image (bout 3000x2250 res) basically when u render the default max render window comes up and also ure frame buffer. So...you will need to Hit F10 then 1 - under the renderer tab in the frame buffer untick the get resolution from max option. Set ure res to whatever you want (A0 for me its 5000x3350) 2 - in the common tab set the resolution to something like 20x15 under the out put size. 3 - render and save as targa then convert the targa file as jpeg in PS thats how i get a high res image out...it works for me. Hope this helps. Link to comment Share on other sites More sharing options...
Gilban Posted March 13, 2008 Share Posted March 13, 2008 Hi bijoy then what is the use of this? 2 - in the common tab set the resolution to something like 20x15 under the out put size. Link to comment Share on other sites More sharing options...
nivvu Posted March 14, 2008 Author Share Posted March 14, 2008 Thanks for ur solutions guys, i wil give a try !!!!!!!!! Link to comment Share on other sites More sharing options...
Claudio Branch Posted March 14, 2008 Share Posted March 14, 2008 always render to a .vrimg file for excessively oversized renderings with vray. Does this work if you are using distributed rendering as well? Link to comment Share on other sites More sharing options...
bijoy Posted March 16, 2008 Share Posted March 16, 2008 Well im not sure, but its got something to do with memory management or something like that...i had a decent computer as well and still had that problem with memory. Because i was setting the resolution in that common rollout tab and then in the frame buffer, i set it to 'get resolution from max'. So i had two 5000x3350pix windows opening up...one from max and one from the frame buffer. Sometimes i would not use vray and just use the default scanline to render and even then it will still give some sort of error. Something with that god damn max render...haha(the solution for that was to merge the old file with a new one and render...sheesh). So after doing it the other way (for vray) i got the problem fixed. Link to comment Share on other sites More sharing options...
TomA Posted March 21, 2008 Share Posted March 21, 2008 Could you not also render it in regions, e.g. 4 quarters then piece them together in Photoshop? Link to comment Share on other sites More sharing options...
nivvu Posted March 21, 2008 Author Share Posted March 21, 2008 yes, i have rendered the scene in to several peices and then joined in photoshop.......thanks again for ur solutions guys..... :-) Link to comment Share on other sites More sharing options...
JayTee Posted January 15, 2011 Share Posted January 15, 2011 Here are some tips how to avoid Vray crashing while trying to render large image: http://3d-visualisointi.blogspot.com/2011/01/vray-memory-error-problem-rendering-big.html Link to comment Share on other sites More sharing options...
