Vray Mirror Material
TomA
Anyone know a good Vray mirror material?
I've created one with these settings but i've got a hunch they're a little dodgy:
Diffuse Raytrace map set at 100%, Reflection colour set to white, refraction to black, shader set to Phong, and that's about it.
Know a better 1, or how i can change mine to make it better?
Tar
:D
default "blinn" works.
As another note, I always make my mirrors with a diffuse color of black of course and only about 98% reflective, not 100%. It helps it to read, specifically in small rooms where the wall color behind the mirror is the same as the color of the wall in the reflection.
  • 11 months later...
  • 3 years later...
here is an example of what i want:
http://www.mr-cad.com/mrcad-blog/ref...caustics-9.jpg
thanks
this effect is called reflective caustics (see the name of that picture you have posted :-)
its quite tricky to tweak the settings - its based on the photon mapping in most cases
see vray on-line help here http://www.spot3d.com/vray/help/150SP1/ for more info - its far to complex for this forum..
i dont use rhino and i am not the caustics or photon mapping specialist, but as i remember....
if you are using sun, u have to watch the "photon emit radius" setting (its the radius of the tube gizmo around the sun object) - I hope its same in rhino...
try to keep the radius as small as posible - smaller radius means less photons = less memory, time etc.
your mirror should be inside the green tube gizmo representing this setting (photons are not emitted outside the gizmo)
