TomA Posted March 15, 2008 Share Posted March 15, 2008 Hi, Firstly i'm not sure if this is a Max or specifically Vray problem, partly because i'm not sure how to acheive the effect i'm after, so apologies if this is in the wrong forum. I want to a create a material or object with this texture rendered in Vray: http://i260.photobucket.com/albums/ii31/puttyface_101/max%20help%201/lrgscrrunch.jpg I'm then thinking of applying this diffuse/opacity map to it for surface appearance: http://i260.photobucket.com/albums/ii31/puttyface_101/max%20help%201/MetalsOrnamentalMetalsPlateMeshbron.jpg So kind of a folded bronze/copper mesh, for the back wall of a bar i'm working on. The dimensions of the piece will be 4 metres high by 24 metres long. In short i'm not sure if this is a modelling or material problem or both, and i'd ideally like it to have a low poly count, because it's part of a bigger more complicated building model. Also, if anyone happens to know who might supply such a material, ideally in England that would be great. Thanks P Link to comment Share on other sites More sharing options...
