Spacelord Posted March 20, 2008 Share Posted March 20, 2008 Is there a way to match a 3D camera to a photo that has been made up out of a couple of photos stitched together ? At the moment I am just fudging/covering the result in photoshop. cheers Link to comment Share on other sites More sharing options...
Justin Hunt Posted March 20, 2008 Share Posted March 20, 2008 When I match a stiched photo, I try to use the centre photo's perspective. IE I only match up to one unstiched photo then in PSD I drop the render onto the stiched photo. if that make sence jhv Link to comment Share on other sites More sharing options...
Spacelord Posted March 20, 2008 Author Share Posted March 20, 2008 If you match the camera's FOV to the center photo and the aspect ratio. Then everything on either side of the stitched photo is not rendered. So how do you adjust the camera to compensate for that ? Do you adjust the aspect ratio to fit everything ? I had thought about trying the cyclindrical lens shader in mental ray. I might give it a go. Link to comment Share on other sites More sharing options...
Spacelord Posted March 20, 2008 Author Share Posted March 20, 2008 Just another thought, I could (like you said) match the middle photo. Rotate the camera to match the next image, render them out and stitch them together. It would probably get pretty messy. mmmm Link to comment Share on other sites More sharing options...
Justin Hunt Posted March 20, 2008 Share Posted March 20, 2008 I tried the second methode and yes it is messy. How wide is the stich compared to the middle image? and how much of the model sits in the stiched area? Basically, I use the middel image to first line up the model, then adjust the aspect ratio to that of the stiched image, without changing the camrea lens jhv Link to comment Share on other sites More sharing options...
RJL Posted March 20, 2008 Share Posted March 20, 2008 The ideal method would be to ensure that everything you need to render lives in the center portion of the stitched image so you can view match to one photo. You can then render your CG elements to that aspect ratio to bring into Photoshop and locate in your stitched image using the extents of the center photo as a guide. If you need to render content for all pieces of the stitch it's much tougher because the optics are much harder to figure out. You may end up having to stitch your CG as well...?? I've had to do that before and it's not fun, especially if you do a lot of post (render mattes, passes, etc.) Link to comment Share on other sites More sharing options...
bjornkn Posted March 20, 2008 Share Posted March 20, 2008 You don't mention how the images were stitched. If they are a plain flat, rectilinear stitch you should know the horisontal and vertical fov (I use PTgui for stitching, where you always know those parameters)? Given those fov's I set up the camera accordingly (in LightWave) and rarely have any problems. It is very important to not crop the stitch until the composite is ready though, or else you'll often have big problems. If your stitch is cylindrical or spherical you'd need to set up a cylindrical or spherical camera, or map the background on a cylinder or sphere. Link to comment Share on other sites More sharing options...
Spacelord Posted March 21, 2008 Author Share Posted March 21, 2008 I've tried 2 ways of stitching in photoshop, Perspective and cyclindrical, I think Perspective works better. The main problem is the photos don't have much for me to work from, theres no buildings, theres only a road, grass and trees to work out the perspective\FOV. I think I'll just end up using the photos as a background and create most of the stuff in the foreground. Link to comment Share on other sites More sharing options...
bjornkn Posted March 21, 2008 Share Posted March 21, 2008 Maybe if you try with some better stitching software, like PTgui (Pro) or Hugin (free) it will be easier? At least it will give you the hfov and vfov directly, and the correct crop. It will be trickier if you don't have any existing buildings in your photos, but on the other hand you are also more free to "interpret"? Attached is an example with a 104x60 degrees stitch that has been cropped some after compositing. Link to comment Share on other sites More sharing options...
Spacelord Posted March 22, 2008 Author Share Posted March 22, 2008 Thanks Bjorn, I'm trying ptgui, the FOV the ptgui is giving is focal length 8.366mm, focal length multiplier 4.448. Whats the multiplier for ? Do I need to take this into account when setting the Focal Length ? I also remember hearing that the 3dsmax camera will never match a real cameras FOV. But I guess this should give me a starting point. cheers Link to comment Share on other sites More sharing options...
bjornkn Posted March 22, 2008 Share Posted March 22, 2008 You don't have to bother with the focal lengths, because that is a property of the source images anyway. The numbers you need are the panorama settings, which can be set from the Tab of the same name, or interactively from the panorama editor window. The multiplier is like crop factor, for 35mm equivalent focal lengths - but you don't need it. I don't know about Max cameras, but in LW I set the camera output size to the same as the exported non-cropped (very important to not crop it!) panorama. Then I set the hfov, and the vfov will follow automatically. And then moving the camera around usually works fine for aligning buildings with background. I also use the Photo Match in SketchUp on such stitched images, and when I import the scene with cameras into LW I get the correct locations, but often need to adjust the focal length to make it fit exactly.That is a process that requires exisiting buildings though. Link to comment Share on other sites More sharing options...
Spacelord Posted March 22, 2008 Author Share Posted March 22, 2008 thanks, So what your talking about is the aspect ratio Width X Height and you just figure out the FOV yourself. Link to comment Share on other sites More sharing options...
bjornkn Posted March 22, 2008 Share Posted March 22, 2008 No. The FOV is not directly linked to the width/height. You may have a hfov anywhere between 2 and 120 degrees, depending on the focal length, and still have the same aspect, 4:3 or 3:2 or whatever. But if you have a given hfov of, say 100 degrees, and size of 4000x2000 pixels, you can easily calculate the vfov from those numbers: vfov=(hfov/w)*h or vfov=(100/4000)*2000= 50 degrees. Focal length is really not telling you anything unless you know the physical size of your sensor, which for most 3D programs probably is set as default at the 35mm standard 24x36mm, for a 3:2 aspect ratio. But most computer formats/screens aren't 3:2 ratio anyway, and then the focal length is kind of useless. FOV will however tell you the exact field of view regardless of your aspect. If you increase the height of the image you will get a higher vfov if the hfov stay the same. Unfortunately the 34mm standard on film cameras have "taught" us to think of a 50mm focal length as a normal lens, instead of thinking of the fov as a standard, which for that lens on 36x24mm film would be hfov=47degrees and vfov=27degrees. Your lens would then use the multiplier in PTgui to calculate the equivalent focal length for the same fov on film, which would give it a focal length of about 37mm (8.366mm*4.448). You may use that in a 3D program, and set the "film size" to 35mm, but I find it much more predictable to use the hfov and vfov. Link to comment Share on other sites More sharing options...
