chow choppe Posted March 20, 2008 Share Posted March 20, 2008 is it the time to switch from max9 to max2008 which is better out of the 2 we are using 64 bit windows and quad core machine Shall we shift to max 2008? is it worth it? i hope there are no directx problems with it or any other max plugins we will be using vray egz materials onyx tree storm particle flow real flow glu 3d are the out for 2008 64 bit version Link to comment Share on other sites More sharing options...
DavidR Posted March 20, 2008 Share Posted March 20, 2008 Unless there's a feature you really need in 2008, the argument for upgrading isn't very strong. Link to comment Share on other sites More sharing options...
jkletzien Posted March 20, 2008 Share Posted March 20, 2008 We haven't yet, but this thread did catch my eye. http://forums.cgsociety.org/showthread.php?f=6&t=595944&highlight=MAX+2008+Stable I guess it depends on who you believe.... Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted March 20, 2008 Share Posted March 20, 2008 I would just check with Nextlimit and Glu3D guys, as they're historically not the fastest to update their stuff I've been using 08 for some smaller projects to test so far and its been running perfectly here. (Once you get rid of the new select by name crap) I do find it very noticeably faster in the viewport. Link to comment Share on other sites More sharing options...
chow choppe Posted March 20, 2008 Author Share Posted March 20, 2008 I would just check with Nextlimit and Glu3D guys, as they're historically not the fastest to update their stuff I've been using 08 for some smaller projects to test so far and its been running perfectly here. (Once you get rid of the new select by name crap) I do find it very noticeably faster in the viewport. yeah they have really messed up the new select by name appearance. How to get rid of that? Link to comment Share on other sites More sharing options...
mattclinch Posted March 20, 2008 Share Posted March 20, 2008 yeah they have really messed up the new select by name appearance. How to get rid of that? Go to the location of your CurrentDefaults.ini file - \Application Data\Autodesk\3dsmax\2008 - 64bit\enu\defaults\MAX Right at the bottom of the ini file (CurrentDefaults.ini) you will find the string: [scene Explorer] SelectByNameUsesSceneExplorer=1 Change to: [scene Explorer] SelectByNameUsesSceneExplorer=0 Save and reopen MAX Never had any issues with 2008. Speed increase was superb on my system and its been solid as a rock stability-wise. Link to comment Share on other sites More sharing options...
Logitek Posted March 20, 2008 Share Posted March 20, 2008 Never had any issues with 2008. Speed increase was superb on my system and its been solid as a rock stability-wise. Really? My Max 2008 copy has been sitting on my desk for 4-5 months... never had/took the chance to install it in fear something might be messed up in my workflow... I guess I could/should make the jump now... Link to comment Share on other sites More sharing options...
chow choppe Posted April 24, 2008 Author Share Posted April 24, 2008 Go to the location of your CurrentDefaults.ini file - \Application Data\Autodesk\3dsmax\2008 - 64bit\enu\defaults\MAX Right at the bottom of the ini file (CurrentDefaults.ini) you will find the string: [scene Explorer] SelectByNameUsesSceneExplorer=1 Change to: [scene Explorer] SelectByNameUsesSceneExplorer=0 Save and reopen MAX Never had any issues with 2008. Speed increase was superb on my system and its been solid as a rock stability-wise. thanks that helped Link to comment Share on other sites More sharing options...
SandmanNinja Posted April 24, 2008 Share Posted April 24, 2008 I remember reading your original tip, but couldn't find it and wasn't sure who posted it or any particular phrase to search for. Now that I have Max 2008, I've copied your tip to my Max Notes section. The new scene picker isn't horrible, but I'm use to the 'old fashioned' way of picking, and I think the new one is a bit slower. Thanks! Link to comment Share on other sites More sharing options...
