lefks Posted March 20, 2008 Share Posted March 20, 2008 Hi, I am new to revit and I am importing a dwg file into revit that was exported from 3ds max. The model is faceted, not smooth. Is there a way to smooth my object in revit? Thanks Link to comment Share on other sites More sharing options...
Tay othman Posted March 20, 2008 Share Posted March 20, 2008 Hello Lefks When you import a 3ds mesh in Autocad ...it will be imported as a polymesh which it's not supported by Revit....it will remain faceted...there is no solution coz autocad and revit only support NURBS objects. My Advice is to make your model in nurbs inside max and then export it into an IGES the use IGES import for autocad to change it to dwg then import it into revit any need for help never hesitate regards tay Link to comment Share on other sites More sharing options...
lefks Posted March 20, 2008 Author Share Posted March 20, 2008 thanks so much Tay, that really helped! Link to comment Share on other sites More sharing options...
