murtazasimari Posted March 24, 2008 Share Posted March 24, 2008 hiii guys i am working on a big project i find some difficulties to create a ceiling w/ cornice & indirect lighting i also attach one picture for reference plz if you give me your advice & some nice tips it will be highly appreciate.. thank you Link to comment Share on other sites More sharing options...
SandmanNinja Posted March 24, 2008 Share Posted March 24, 2008 For the 'drop cornice' (for lack of a better word), just do the cornice the normal way (select the edges of the upper wall, convert to shape, then loft or sweep the cornice shape to the line) and then lower the loft or sweep. Then put some lights in the space between the top of the drop cornice and the ceiling. As I look at it again, I guess you'd need to have two lofts/sweeps - one for the lower cornice and one for the upper (thin and wide) cornice. To get the detail into the lower cornice, I'd have to Boolean it in (somehow). Link to comment Share on other sites More sharing options...
murtazasimari Posted March 25, 2008 Author Share Posted March 25, 2008 For the 'drop cornice' (for lack of a better word), just do the cornice the normal way (select the edges of the upper wall, convert to shape, then loft or sweep the cornice shape to the line) and then lower the loft or sweep. Then put some lights in the space between the top of the drop cornice and the ceiling. As I look at it again, I guess you'd need to have two lofts/sweeps - one for the lower cornice and one for the upper (thin and wide) cornice. To get the detail into the lower cornice, I'd have to Boolean it in (somehow). thanks for your reply...but i wanna know which type of light is suitable for this view and as u saw there is very minute detail in lower part just tell me how i achieve all this detail..plz help me out Link to comment Share on other sites More sharing options...
tanni Posted March 25, 2008 Share Posted March 25, 2008 Vray, GI Use vray physical light and light materials. I think this will help you. Link to comment Share on other sites More sharing options...
murtazasimari Posted March 31, 2008 Author Share Posted March 31, 2008 Vray, GI Use vray physical light and light materials. I think this will help you. Thanx tanvir i tried with vray lights but still i need indirect ceiling lighting same like that above view..plz if u have any idea just let me know Link to comment Share on other sites More sharing options...
mattclinch Posted March 31, 2008 Share Posted March 31, 2008 by 'indirect' ceiling lighting i assume you are referring to the bounced light being emitted from the recess in the cornice. As Tanvir pointed out, this is best achieved with a Physical Area light, stretched out to act as a 'strip' light, similar to a cathode tube. Make sure you have lots of GI bounces to really kick that light all around the scene, given that it will need 2 or 3 to get itself out of the cornice area and illuminate your room. Link to comment Share on other sites More sharing options...
kippu Posted March 31, 2008 Share Posted March 31, 2008 use vray lights inside the cornices pointing upwards and then some other vray lights outside the cornices pointing downwards.. and play with the values Link to comment Share on other sites More sharing options...
