More Backburner issues
Tim Saunders
I may never get Backburner to work. But I need to soon.
My server and manager connect just fine, I even see the system(s) in my servers list when submitting the job.
I'm just keeping things simple until I can figure out the issue. All I am doing is opeing the manager and server on one workstation, and rendering it on the same system, for batch rendering purposes. You know, so I can render several images while I go home at night.
Once I click submit, the application starts working just for about a second, you'll see a max tab minimze really quick, then the manager shows the following issues:
WRN Task error from
ERR Job 'the job name' (Autodesk 3ds Max 2008) failed for
ERR Error message: Unknown error while loading application.
WRN Server flagged as failed for job 'the job name'
Does anyone have any ideas to resolve this issue?
Gosh, I think I've seen this one before but I'm trying to remember what fixed it.
Do you have multiple versions of Max installed on your machine? It seems like I had some trouble when I was inadvertently opened the server application for Max 7 when I was submitting Max 9 jobs.
Which version of Backburner are you using? I know that the first release of Backburner 2007 was a real stinker and AutoDesk has quietly offered a couple of service packs for it.
Those are the two things that come to mind. If my feeble brain recalls anything else, I'll let you know.
I got the same error when i was building our farm....sounds to me like its opening max and then having trouble opening the scene.
go into program files\autodesk\backburner\server jobs and see if there is any files for your job in there, and then see if you can delete them. Our systems where setup so certain logins can't edit content in the program folders drive, which meant backburner couldn't edit those files, let alone the backburner.xml file which caused my jobs to error out.
what is the server window saying as all this happens?
I'm only running Max 2008, no other versions. I'm not sure how to tell what version of BB I have. Whatever came with Max 2008. The only service pack for BB is for Max 9, nothing out for Max 2008 yet.
I'l try deleting the jobs in the ServerJob folder and see what happens.
The server window doesn't have any new notes when the problems occur.
Start Backburner manager and then click on "help" and then about backburner. I think that Max 2008 still uses backburner 2007 but I don't have an install handy to check. If it is backburner 2007 and its not service pack 2 I would install it from AutoDesk.
you know when I was trouble shooting my farm, I tried backburner 3.2, 2007.0.2, and finally 2007.1 and in the end it had nothing to do with the updates to backburner that was causing the headaches.
and to illustrate that I know that there are a couple of the computers in my network with different versions of backburner, and its all fine now. The updates to backburner aren't really functionality issues such that it's going to fix your problems. The updates were more about error reporting and keeping the manager from crashing.
I know that the majority of my machines now are loaded with the stock backburner off of the 3dsmax2008 install.... so I wouldn't even waste time looking for a fix out of upgrading BB.
The good old "unknown error". Obviously max knows what's going on, but it's not going to tell you. In my experiences, this error is usually file related. However, that's not always the case.
I would try the recommendation of using a super simple scene with no textures and a box and plane. You might think your existing scene is super simple but if there is something in there that may have gone corrupted that could be causing your file to crash. Maybe it's texture related. For example I had a file that worked perfectly locally, but crashed every time on the farm. After some extensive looking into, a group head inside the file had gotten corrupted and for whatever reason as soon as the file was attempted to load over the network the thing crashed.
What's the memory load when the scene crashes? Does it crash all the time, sometimes a file will crash 3-4 times in a row then render perfectly fine.
If the server still crashes the file then it may be something on your machine and you'll have to look deeper into the backburner install. What happens if you run the manager on your machine then try to render your scene on another workstation connected to that manager?
This may sound too simple and you probably have checked it already, but under the server settings, is the Server Name or IP Address set to the name of the machine it is on? Using the name, not the IP, works for me.
Manager Name or IP works only with an IP address.
I had to battle through three things.
First, I've only been with this company for just over four months, and not having worked with this IT group, I didn't know that some logins aren't given access to edit content in the program files directory. If backburner can't edit it's .xml file it can't hold it's server location data. Getting my credentials adjust fixed that one.
Second problem, our computers have two....well actually three firewalls installed on them. Windows firewall (which doesn't count), a Cisco, and a Norton. I knew about the Cisco and put an exception in it for the systems I was using. The Norton program was running in a hidden mode and only on half the systems so it was real perplexing why I could ping half the systems one way, and the other half back but never all at each other.
And the Third was that we have a large office (+200) computers, and it's running on two subnets. Backburner can only operate on one subnet. Since machines are on dynamic IP addresses and I have the manager set on 10.10.9.xxx subnet, if a machine reboots and comes up with an IP on the 10.10.10.xxx subnet then it won't work. The frustrating thing about that one is, it will find the manager, register with the manager but can't take a job from the wrong subnet, this one really confused the hell out of me and still bothers me. So I have about 60 machines on this floor available for rendering at night, but about 10 - 20 of them come up occasionally on the wrong subnet.
I now have farms in three of our offices, Boston and Columbus were easy setups because they are smaller offices. But SanFran because of it's size threw a couple of kinks into how I am accustomed to doing it. (Or I should say how I learned from travis :D ) But I now have a really strong understanding of how backburner works..... so I guess it was worth beating my head against a wall for three weeks????
Well, now I'm in a whole new battle. Last night, I tried updating the BB service pack as suggested by someone else. One of the steps Autodesk tells you to do is, uninstall the existing BB. I did that, but when I try to run the install, I get this:
What does that mean, and how do I get past that? Because now I'm further away than I was, because I have NO BB now.
I'm pretty sure if you set BB to use subnet 255.255.0.0 it should be able to see and work across both your 10.10.9.x and 10.10.10.x addresses.
I'll have to give it another go round. Initially I was doing it as you mentioned and it wasn't working so I switched off the search and manually entered the manager's IP (pretty dumb when IPs are dynamically allocated) but it seemed to work. Now that I have the two other problems sorted out.... now that I think about it I should go back and retest this one.
I did find a post on an autodesk site that said backburner is limited to 255 machines because it can only work off of one subnet.
http://discussion.autodesk.com/thread.jspa?threadID=588482
maybe they are just assuming that guy specifically is only operating on one subnet.
There are two logs that you should be checking to see what information is displayed:
Server Log: C:\Program Files\Autodesk\backburner\Network\backburnerServer.log
This is the default install path - yours may be slightly different. This log file is present on all server machines.
Manager Log: C:\Program Files\Autodesk\Backburner\Network\backburner.log
This is also the default install path. This log file resides only on your manager machine.
Tell us what - if anything - these logs say. If there is no useful information you could try increasing the log level on both server and manager. This is done by going to the Edit -> Log Settings menu in either the Server or Manager application dialog.
It *is* limited to just one subnet BUT one subnet does not necessarily equate to only 255 addresses. The 255.255.0.0 subnet equates to 65536 uniquely addressable IPs.
MATT you rock!
good call.... up and running now thanks chief, I'm not sure I would have tried after I had it working, but you were right now I'm firing on all cylinders. THANKS
