danb4026 Posted March 28, 2008 Share Posted March 28, 2008 I am woking on a compicated object and need to use Named Selection Sets. For some reason, it wont allow me type into the "name selection set" dialog box or thru the "edit named selection sets". I simply can't do it. I use max 2008 64bit with vista 64. I am in Poly sub-objegct mode within edit mesh. Anyone have this issue before? Link to comment Share on other sites More sharing options...
SandmanNinja Posted March 28, 2008 Share Posted March 28, 2008 It's always worked. There is a different set of Named Selections depending upon what selection mode you're in: i.e. poly, edge, vert... Link to comment Share on other sites More sharing options...
danb4026 Posted March 29, 2008 Author Share Posted March 29, 2008 Not sure what you mean. Is there a reason it isn't working? Link to comment Share on other sites More sharing options...
SandmanNinja Posted March 29, 2008 Share Posted March 29, 2008 I guess I'm saying my selection set has always worked. I was just saying that there is a different selection set depending upon which mode you're in: poly, edge, vert, border. Link to comment Share on other sites More sharing options...
danb4026 Posted March 29, 2008 Author Share Posted March 29, 2008 mine has always worked too...thats why I dont know what's wrong. Link to comment Share on other sites More sharing options...
tanni Posted March 30, 2008 Share Posted March 30, 2008 Did you try to do this in previous version of max (3ds max 8)? Link to comment Share on other sites More sharing options...
danb4026 Posted March 30, 2008 Author Share Posted March 30, 2008 It worked fine in all other versions of Max. It also worked in this version of max up until this week. Link to comment Share on other sites More sharing options...
SandmanNinja Posted March 30, 2008 Share Posted March 30, 2008 you could try blowing away the 3dsmax.ini file. Does it do it with an empty scene? Like, open max, draw a box, convert to editable poly, pick a face, make a named selection set, switch to vert, pick some verts, make a named selection set, switch back to poly. Is your first set there? I know the 3dsmax.ini file controls some settings from max scene to max scene. Not sure what else would. Link to comment Share on other sites More sharing options...
danb4026 Posted March 31, 2008 Author Share Posted March 31, 2008 what happens if you blow away the ini file? Link to comment Share on other sites More sharing options...
SandmanNinja Posted March 31, 2008 Share Posted March 31, 2008 It makes a nice, clean one. I do this if I 'lose' a toolbar or window. Max has to have this file, so if it cannot find it, it makes a new one. You can always rename it instead of deleting it, but I've combed through an old, bad one and it would take a lot of thinking and deducing to get anything useful out of it. Link to comment Share on other sites More sharing options...
