TomA Posted March 31, 2008 Share Posted March 31, 2008 Hi, I've got a concert hall model which i'm editing but i'm not sure how to light it in vray. I'm begining to get used to lighting with a sun but not very good with black box spaces with purely artificial light. I'd like to achieve lighting similar to these (basically warm and rich with the lighting focused on the stage but with accents around the space): http://i260.photobucket.com/albums/ii31/puttyface_101/concert%20hall%20help/walt-disney-hall-1.jpg http://i260.photobucket.com/albums/ii31/puttyface_101/concert%20hall%20help/jack_singer_concert_hall01.jpg http://i260.photobucket.com/albums/ii31/puttyface_101/concert%20hall%20help/3673_Concert20Hall20interior20120Ni.jpg I've got a vray light sphere in my scene above the stage and that's it. What sort of lighting setup would you recommend? plus how would you do the highlights/spotlights? Cheers P Link to comment Share on other sites More sharing options...
kippu Posted March 31, 2008 Share Posted March 31, 2008 i would suggest using photometrics with target directs? ...get a nice ies data from a lighting manufacturer website and you should be good to go oh longer render times await you Link to comment Share on other sites More sharing options...
Horhe Posted March 31, 2008 Share Posted March 31, 2008 I wouldnt recommend using too much IES lights - just the ones near walls that will give a wash. Just a couple of lights to light the overall space and a selfilluminating map for most of the lights to make them glow. Link to comment Share on other sites More sharing options...
TomA Posted March 31, 2008 Author Share Posted March 31, 2008 aren't photometrics intended for mental ray more than vray though? sounds like an interesting idea though, using proper IES data, if not a little pedantic? thanks for the illumination map idea, i think i'd probably do something like that anyway. but i guess i'm generally on the right track here, so that's ok... i think a fair bit of post production in photoshop will help a lot too! Link to comment Share on other sites More sharing options...
landrvr1 Posted April 1, 2008 Share Posted April 1, 2008 aren't photometrics intended for mental ray more than vray though? sounds like an interesting idea though, using proper IES data, if not a little pedantic? thanks for the illumination map idea, i think i'd probably do something like that anyway. but i guess i'm generally on the right track here, so that's ok... i think a fair bit of post production in photoshop will help a lot too! IES is really a cross-platform generic lighting solution. In other words it's great for VRay. I never use them, though the effect they bring to your scenes are amazing. As kippu said, expect a serious jump in rendertimes. How serious? Plan on hitting the render button and heading out for the weekend. Link to comment Share on other sites More sharing options...
TomA Posted April 24, 2008 Author Share Posted April 24, 2008 Sounds like Photometric/IES lights are very heavy on RAM? That is if render times are dramatically increased. Link to comment Share on other sites More sharing options...
kippu Posted April 24, 2008 Share Posted April 24, 2008 no they are not heavy on ram , i suppose...the light calculations are processor intensive Link to comment Share on other sites More sharing options...
ApeiNe Posted April 25, 2008 Share Posted April 25, 2008 I would also say to use IES near the walls to get some great light shapes, jsut start with that, render it in low, then add some vraylights to get close to your references IES is a bit more longer to render, you can try to exclude some parts of the scene to render it faster, the parts doesn't have so much influance, far from the source itself let us know and see when you finish it Link to comment Share on other sites More sharing options...
Jason Matthews Posted April 29, 2008 Share Posted April 29, 2008 Oh the render times... It may be a good point to mention that you really have to boost the environment (hdri) map quite a bit. I was working on a church (very schematic) and I noticed a much more even light by boosting it, IMHO. Link to comment Share on other sites More sharing options...
Trevor Tizard Posted April 30, 2008 Share Posted April 30, 2008 This may be of use................ http://area.autodesk.com/index.php/tutorials/tutorial_index/making_of_the_auditorium/ Link to comment Share on other sites More sharing options...
TomA Posted April 30, 2008 Author Share Posted April 30, 2008 Just had a quick scan. Looks awesome thanks! I'll have a proper look later on. Link to comment Share on other sites More sharing options...
Spooner04 Posted May 3, 2008 Share Posted May 3, 2008 IES lights are way overrated in my opinion. They look pretty. But you can easily achieve a similar effect using a vray light or a spotlight without the huge increase in render times. Might not be to much of a factor for just an image or two, but I wouldn't put them in until the very end of the process. Otherwise just taking small region renders to check materials will get very frustrating. Link to comment Share on other sites More sharing options...
Dave Oliver Posted May 6, 2008 Share Posted May 6, 2008 well of course realistic light is going to be the ultimate best option but like they said only the lights near the walls generate that hotspot. instead of many unnecessary lights in the ceiling i would just have a large, dim area light for some general lighting in the space and a self illuminating material in the recesses for the can lights Link to comment Share on other sites More sharing options...
Thablanch Posted May 8, 2008 Share Posted May 8, 2008 I do not think that IES lights are way overrated.. VraySP2 has VrayIES, wich are way faster than standard IES with Vray Shadows ( or even shadow map) The time lost in rendering is time you do not spend in setting up the lights. no fooling around with multipliers.. just need to know the lumens and that's it. Would be nice to find the time to do a 3 way comparaison : standard light vs IES vs VrayIES Link to comment Share on other sites More sharing options...
