SgWRX Posted April 1, 2008 Share Posted April 1, 2008 i'm using a blend material, but don't think that's entirely necessary, i think i could use a mix map as well. put the "short grass" bitmap from the max arch materials in each of the blend maps, then used a gradient ramp as the blend mask. added a uvw map to the plane, in this case 100" x 300" and it seems to work well, i could maybe make it a little smaller. oh, the stripes are achieved by changing the output of the bmp slightly different. both are turned way down due to use FG and mrsun mrsky, they are .35 and .45. the gradient ramp blends the edges together. Link to comment Share on other sites More sharing options...
davistalexander Posted April 2, 2008 Share Posted April 2, 2008 would you mind posting the mat file..... or a scene with a plane.... grass kill me.. thanks davis Link to comment Share on other sites More sharing options...
SgWRX Posted April 2, 2008 Author Share Posted April 2, 2008 no problem. i've tried it now on a few different ground planes and it takes some tweaking with uvw map but in the end i like the way it works out. haven't tried it yet from a big overhead scene yet. Link to comment Share on other sites More sharing options...
