Background not displayed when saving animation to hdr files
ludo21
good day,
I'm working in "so-so" linear space, and thus I'm saving my sequence into single 32bitHDR files, so that I can script-adjust exposition before saving to 8 bits...
I'm saving 1 file/frame.
My scene is a lil interior scene with an exterior HDR background mapped spherically.
So far, no problem.. when I'm saving individual frames into HDR files, all is fine.
But when I'm rendering a small sequence (even 3 frames), saved in HDR format, the background is displayed black not anti-aliased between the 2d trees, and it appears only though the trees' transparency.... :confused: weirdo...
And when I'm saving the same sequence in JPG format, it's all fine, but very dark, naturally...
EDIT > 2 images showing the problem attached ;
Any help ? HELP !!!! :(
thanks in advance,
Ludo
I must add that the problem disspears with HDR Low pixel format (to be used when no Gbuffer is present)... would this all be a G-buffer problem ? I raised it from the default 10 value to 15.. it didn't help with the full 32 bit HDR sequence format "bug"...
I may switch to LDR HDR then...
