TomA Posted April 3, 2008 Share Posted April 3, 2008 How do you vary material maps in Max, so that they aren't really repetitive over a large area, ideally without using Unwrap UVW? Link to comment Share on other sites More sharing options...
BrianKitts Posted April 3, 2008 Share Posted April 3, 2008 How do you vary material maps in Max, so that they aren't really repetitive over a large area, ideally without using Unwrap UVW? Use larger sized maps, and learn how to use the offset filter in photoshop to paint out any tiling in your maps. Link to comment Share on other sites More sharing options...
trino Posted April 3, 2008 Share Posted April 3, 2008 try these tuts: http://www.gfxartist.com/features/tutorials/740 http://blog.paranoidferret.com/index.php/2007/05/06/photoshop-tutorial-create-a-seamless-texture-from-a-photo/ http://www.bitbrush.com/tutorial1.html Hope it helps. Link to comment Share on other sites More sharing options...
TomA Posted April 3, 2008 Author Share Posted April 3, 2008 thanks v much! i've had a quick scan of those tutorials, i'll have a better look later. so it's essentially a photoshop issue then? Link to comment Share on other sites More sharing options...
BrianKitts Posted April 3, 2008 Share Posted April 3, 2008 so it's essentially a photoshop issue then? not necessarily..... it's an issue of the quality and setup of the maps you use. Photoshop is just a good (but not the only) tool to fix the problem. Blend materials is another option depending on the scenario for masking a tiling material. Link to comment Share on other sites More sharing options...
