vRay light material problem
wacky715
ah iv just had this problem as well with phys cam, hadnt noticed it before
what do you do when you want the vray light mat visible but dont want it affecting GI with the high multipliers you need to make it visible?
make it not generate GI?
thanks
thanks
When u are usin Vray phiscam, i have to set mult for VraylightMtl up to 2000 or higher becuase of exposure control. As for visible Vraylightmtl but not generating GI use VrayOverideMtl, see the manual or here: http://www.spot3d.com/vray/help/150SP1/vray_overridemtl.htm
Basicaly for neon I use VrayOverideMtl with two VrayLightMtl - Base for color; GI to generate GI. Multipliers for base from 2000 to 6000(depend on your ISO/f-number/shutter speed) and for GI 10000 - 60000.
Hope it helps.
  • 3 years later...
hello! i need help in my vray light material whenever i put it on an object. it is not showing. The object that i placed a vray light material is just black when i render.
Hi,
did u find a solution ? I have exactly the same issue here!
If u found a solution I would appreciate if u could share some light ^^
cheers
Vito
When you get the vray light material. the multiplier wud be 1. In case it is black when you render the scene, then you have you increase the multiplier. it also depends on the camera settings, GI etc. so try increasing it from 1 to higher values(example - 50). if it is too bright then make it less value. *make sure the EMIT BOTH SIDES is on..
thanks enjoy
thanks
Right click on the object you have applied the light material and go to vray properties. In that you can find GENERATE GI parameter which is set 1 as default. make it 0.2.. that will reduce the GI generation by that object..
thanks
enjoy.
