3ply Posted April 8, 2008 Share Posted April 8, 2008 I've had some major problems with Viz lately. I would open an older Viz file (Viz2006) and start rendering it in Viz 2008 and it would crash. So I check various other files and they would also crash. So I email a Viz Tech about the problem. They tell me I should collapse all my modifier stacks and then save it and open it up into the newer version... That is the worse thing I want to do. How do you easily modify the objects? Everything is turned to mesh It's like flattening a photoshop file with multiple layers and saving it so I can use it in a newer version. Or exploding the smart ADT objects in autocad. Whats everyone else think of this?? What I've done in the past is merge objects from another file into a newer file. This seems to help with some crashing. I've also noticed that any ADT object from AutoCad ADT would have errors. I used the STL error checker. Is this common that ADT objects are corrupted when imported into Viz?? Has anyone else run into these issues?? Link to comment Share on other sites More sharing options...
Conor Clancy Posted April 9, 2008 Share Posted April 9, 2008 Although I don't use ADT I did recently upgrade from Viz 2005 to 2008. The problems you describe are very familiar to me. The merging of the files into a fresh scene is also the only way I could get a lot of older files to work in 2008. Even then, when I need to make changes to older images, I just load them up into 2005. It's easier and much less frustrating. Is it just me or does anybody else think Viz 2008 needs an enormous service pack up the a$$. Link to comment Share on other sites More sharing options...
