Cookiepus Posted April 10, 2008 Share Posted April 10, 2008 Hello I've modelled my building using AEC walls, im now doing a simple white render for client preview. Im getting these huge dark blotchy edges on the corners of the walls. When i turn up the qulity setting in Vray they are reduced but still quite noticeable. As you can see from attached image. It doesnt happen with regular polygon objects, but i hope to God i dont hafta sart over! Any help appreciated......... Link to comment Share on other sites More sharing options...
Joseph Petrino Posted April 10, 2008 Share Posted April 10, 2008 That looks like co-planner faces. Bump up "secondary rays bias" just a little. That usually fixes the problem. Link to comment Share on other sites More sharing options...
Cookiepus Posted April 10, 2008 Author Share Posted April 10, 2008 Thanks Joeseph That worked a treat! Just put it at .001 Like this........ http://www.vray.us/vray_documentation/vray_global_switches_examples.shtml Link to comment Share on other sites More sharing options...
alfienoakes Posted April 11, 2008 Share Posted April 11, 2008 If thats in Architectural desktop the faces shouldn't be co plainer unless there is a problem with the cleanups / geometry.. If it were me, I would rather get the CAD model working correctly, and you will see the Vray problem removed as well. Link to comment Share on other sites More sharing options...
