warprat Posted April 14, 2008 Share Posted April 14, 2008 Hello, Lately I tried to render an image to 6600 x 4800, an error came out saying "error creating bitmap". I am using 3dsmax 8 and vray 1.5rc3 a 2.4 quad core, 2 gb ram, nvidia 8800 gpu. What sort of specs do I need to be able to render out such large images? or does it have something to do with my maps. Thanks Link to comment Share on other sites More sharing options...
AJLynn Posted April 14, 2008 Share Posted April 14, 2008 More RAM, 64-bit Windows helps, or at least the /3GB switch (if that makes your video driver fail to load try /USERVA=2800 instead). Turn off the rendered view window. Use instances, Vray proxies and take your computer out for a nice dinner. Link to comment Share on other sites More sharing options...
Tommy L Posted April 14, 2008 Share Posted April 14, 2008 Or you can render in strips. Link to comment Share on other sites More sharing options...
warprat Posted April 14, 2008 Author Share Posted April 14, 2008 Thanks switching of the render view helped a lot! (if that makes your video driver fail to load try /USERVA=2800 instead) what does that mean? I did try win xp pro 64bit 2 months ago but stuff like winamp and pendrives did'nt work. drivers. also, there was a touch of instability now and then. anyhow studio max did work fine even with heavy renders. I am thinking about vista 64 bit. Link to comment Share on other sites More sharing options...
SandmanNinja Posted April 14, 2008 Share Posted April 14, 2008 I say lose the freeware music player and go with a solid OS. I have WinXp64 on my new machine and it's rock solid. Link to comment Share on other sites More sharing options...
warprat Posted April 14, 2008 Author Share Posted April 14, 2008 Sound good man, Is see your Machine specs are like mine. I might give another go at it. thanks Link to comment Share on other sites More sharing options...
AJLynn Posted April 14, 2008 Share Posted April 14, 2008 If the pen drive didn't work... it's a nonstandard pen drive or you have some other problem. USB mass storage is a class driver and XP64 has it - and XP64 does help quite a lot for this sort of thing. Link to comment Share on other sites More sharing options...
warprat Posted April 23, 2008 Author Share Posted April 23, 2008 OK, thanks, right what I done was I installed a new HD, with win xp64bit So now I have 2 O/s's on one pc. So I Installed studiomax9 6x bit with vray 1.5 sp1. rendered a n image at 1500 x 1000, It took 58 minutes. Where as if I rendered the same scene on the 32bit platform it only took 25 minutes. Weird, can anyone tell me why this is happening? Link to comment Share on other sites More sharing options...
