Multiple CPUS/one keyboard one mouse
I'm looking for the best way to work with three separate workstations (networked) with one mouse and one keyboard, with the ability to switch back and forth between the three. Suggestions? I've seen different types of switches out there, but any positive testimonials would help. Thanks in advance!
Thanks for the links...now I'm torn between hardware and software. I found some basic KVM switches out there for around $70.00, but that Synergy software looks interesting, if not the easiest to use...guess I need to do a bit more research. I run Max and Vray, and I wonder if when rendering on one machine, Vray may crash or conflict with something like Synergy...may be best to use the hardware switch...
I think my grandmother had a Singer sewing machine... ;)
I'm looking for something that can handle the frequency from the 8800 GT to both screens with minimum interference. No point in having a nice card and monitors if static is introduced.
I am having a hard time finding a duel screen KVM box. It's a shame we gotta pay close to $100 for one. I remember one for $20 (but that was 1982 I think)
If you are running max and vray, I would just setup the extra machines using remote desktop as mentioned. Then leave both backburner and the vrlserver turned on, and then you only need to visit the extra machines through the remote desktop if something goes wrong. In which case a KVM switch is a waste of money cause you really won't be switching that often. And it won't cost you a thing.
Now if it's a situation where you use one machine for all your photoshop work, and another for all your rendering etc... then a KVM is the right option.
I use a KVM switch for my 4 render machines. It works perfectly. Of course, when I am using networked rendering, I don't use it that often but you still need to boot up or reconfigure setting from time to time.
Save me the eyesore of having 4 monitors/keyboard/mouse next to my workstation. The switch is pretty cheap anyway.
stardock multiplicity peoples. It lets you use 3 pcs like one. Absolutely awesome stuff. and cheap too.
http://www.stardock.com/products/multiplicity/
edit: ok seems like synergy does something simple, but i multiplicity sets itself up with no problems. Just install it everywhere, selecting if it's a host or a slave, and then just re-arrange the monitors in display set up on the primary computer. Easy.
  • 2 weeks later...
Aleksey, I went with your suggestion. You're right, this works flawlessly. You know, I didn't mention that I wanted to control THREE monitors serving THREE cpus with one keyboard and mouse. This simple little program was $50.00 for the Pro version, and it is absolutely perfect. Thanks for all your help and suggestions!
you welcome. Although i feel it's clipboard feature might be lagging the computer. But then again all stardock products are resource hogs.
But otherwise yes, it is perfect: My new room, with lots of lcds
