ncartlidge Posted April 15, 2008 Share Posted April 15, 2008 I'm creating my first vray scene to try and learn how to use it. Everything has been going ok but I'm having a really annoying problem with vray sun brightening the ground too much. For some reason the flat ground around my building is appearing an overly bright yellowy colour.and I can't figure out how to darken it. even if I apply a solid black vray texture to the ground it still appears a funny yellow colour. ive attached the last render i did, believe it or not the plane has a solid black texture on it. I've tried lowering the planes "Recieve GI" value to as low as it can go, but even at 0 it still comes out this colour. any ideas? ive attached my light/camera/render settings. thankyou kindly. Link to comment Share on other sites More sharing options...
chutti Posted April 15, 2008 Share Posted April 15, 2008 try select the ground plane and right click v-ray properties then reduce the Receive GI amount. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted April 15, 2008 Share Posted April 15, 2008 If you create a completely new scene with Vray sun without tweaking any settings, then make a new ground plane, and apply a texture, what happens? ...also, why a turbidity of 6? I doubt that is your problem, but it seems out of whack. You also might want to upgrade to the latest version of Vray. Link to comment Share on other sites More sharing options...
ncartlidge Posted April 15, 2008 Author Share Posted April 15, 2008 chutti - I've already lowerd this to its lowest crazy homeless guy - I'll give this a try. Sun values were based an an example scene I found. Will lower this nearer to the default value. Link to comment Share on other sites More sharing options...
