chow choppe Posted April 17, 2008 Share Posted April 17, 2008 hi all not related to Cg but this problem is regarding some drivers We are using Hp designjet 100 plus plotter in our office connnected to a main server machine which has winxp 32 bit now we share this plotter via lan on other 32 bit Xp machines. but one machine has 64 bit windows and therefore when we try to install that plotter on this machine its not able to find the drivers. We downloaded the 64 bit drivers from the Hp website but we dont know whetehr to install this on host machine or the one with 64 bit windows. second question arises is how i will i be able to install these drivers on host machine since the new drivers are for 64 bit windows. Any other solution or right approach towards our solution ? thanks a lot Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted April 17, 2008 Share Posted April 17, 2008 Intall the 64 bit drivers on the 64 bit computer. The 64 bit drivers are nearly the same as the 32 bit drivers, just complied for a 64 bit machine, and not a 32 bit. I would venture to guess that if you did try to install the 64 bit drivers on the 32 bit machine, it would give you an error message, and not let you install anyway. Link to comment Share on other sites More sharing options...
chow choppe Posted April 17, 2008 Author Share Posted April 17, 2008 i installed those drivers on 64 bit windows and the drivers got installed but now when i give print command my computer gets reallly slow and restarts I tried from different softwares but always the syatem just restarts when i click on print Link to comment Share on other sites More sharing options...
