Box hedge following spline
Matt Sugden
Hi I wondered if anyone could give me some ideas to create a box hedge, or similar kind of hedging which could follow a spline. I'm assuming I'm gonna have to use the scatter command.
I want to do this so I can essentially create spline paths around the landscape and produce nice hedging which dynamically follows the terrain. Any ideas?
Cheers
well I've figured out a solution..... so in case anyone was wondering how I did it...
I created a short section of hedge, about 30cm or so, (by creating a basic truck and branches using spline modeling) then scatter a leaf plane over these sections. Once the section was created I then used the spacing command to run this section of hedge along the path.
Thanks for the suggestions.
This was the kind of effect I have been trying to create, using a single small hedge, which I can map along the spline... I have found once it is mapped using the spacing tool (which seems to be excellent by the way) I can then attach them all together and add some noise to create some irregularity. I think this will be fine for what I want.
Cheers for the help though.
Thanks for sharing your solution.
I absolutely love the spacing tool!
Cheer
