SgWRX Posted April 18, 2008 Share Posted April 18, 2008 do you have to recalculate the FG solution, or if you are writing, when you change the render filter? for example from box to mitchell? thanks Link to comment Share on other sites More sharing options...
SgWRX Posted April 18, 2008 Author Share Posted April 18, 2008 thanks Link to comment Share on other sites More sharing options...
Munz Posted April 19, 2008 Share Posted April 19, 2008 you can also change the Samples per Pixel and Spatial Contrast without having an effecting the Final Gather saved file. Link to comment Share on other sites More sharing options...
SgWRX Posted April 20, 2008 Author Share Posted April 20, 2008 really?! a long time ago i posted something about doing FG calcs at low resolution and a small render size, like 1/4-4 at 320x240 as a memory/time saver. the response was yes, that's a good plan. however over time, i started noticing that if i left the read/write option checked, but the freeze option un-checked, it looked like it was recalculating (much faster) based on the fact that i changed the sampling.. and on other occasions when i changed the render size. so, i figured it made a difference. so just so i'm clear, you don't need to recalc (or, you can calculate then freeze) under these circumstances: 1. changing render output size (320x240 to 800x600) 2. sampling (1/4-4 to 16-64) 3. changing spatial contrast. 4. changing brightness/contrast in exposure control thanks. Link to comment Share on other sites More sharing options...
SgWRX Posted April 20, 2008 Author Share Posted April 20, 2008 ok. Link to comment Share on other sites More sharing options...
Justin Hunt Posted April 20, 2008 Share Posted April 20, 2008 Also if you recalc with read/write on but Freeze off, mr will skip over any existing samples, thus making it apprear to calculate faster, howerver its not updating those existing samples. jhv Link to comment Share on other sites More sharing options...
