RBA Posted April 22, 2008 Share Posted April 22, 2008 Hi, I want to import a .dwg in 3ds, but the curves are not smooth in the 3ds model. Also when I render the scene it is not smooth. The CAD model is near the 0,0,0. I think it is a problem importing the file in 3ds, but what is the problem? I use 3ds VIZ 2006 and ADT 2005. Thnx, Link to comment Share on other sites More sharing options...
RBA Posted April 22, 2008 Author Share Posted April 22, 2008 I have found the answer myself. The surface deviation (by importing the file) was to high (25,4), put it to 0,01 then the surface is smooth after importing the .dwg. Link to comment Share on other sites More sharing options...
Conor Clancy Posted April 23, 2008 Share Posted April 23, 2008 alternatively you can smooth out the faces in Viz using the smooth modifier, or the smooth tools in the edit mesh modifier. Link to comment Share on other sites More sharing options...
adamya Posted August 21, 2009 Share Posted August 21, 2009 apply a vertex weld modifier...surefire--it works...if it needs more smoothing...then appply meshsmooth modifier... Link to comment Share on other sites More sharing options...
