chow choppe Posted April 22, 2008 Share Posted April 22, 2008 hi all i was just practising rendering animation with moving objects using passes for still and moving objects i did my still objects rendering by calculating LC first and the IR with multiframe incremental and then saving it and then rendering the final images afetr that i did the pass for moving objects using high settings and irradiance map and brute force solution i appplied vraymatte materials to the ground planes so as to receive the objects moving shadows. now i am facing a problem in storing the alphas for the shadows. these are the setting for my vray materialwrapper shadows on alpha contribution-1 affect alpha unchecked matte surface----on When i use these settings and render image i dont get alpha channel for shadows area but just the moving object as u can see in point 1 of attached image. now if i click on affect alpha in matte properties i get alpha of shadows as u see in point 2 of attached image. if u see the alpha is not white but transparent white. Now when i try to take this image into after effects and try to comp it over my original image i dont get the shadows as black but they are white and transparent. Can anyone tell me where am i doing wrong i am trying to learn this Thanks Link to comment Share on other sites More sharing options...
chow choppe Posted April 23, 2008 Author Share Posted April 23, 2008 55 views but no reply Link to comment Share on other sites More sharing options...
chow choppe Posted April 25, 2008 Author Share Posted April 25, 2008 nobody knows about it? Link to comment Share on other sites More sharing options...
Nic H Posted April 25, 2008 Share Posted April 25, 2008 Hmm it should be really simple and it looks like you are doing it right allthough I always use vray material object properties rather than the material wrapper but I dont reckon that has anything to do with it anyways. What blending or overlay mode are you using in teh comp? Link to comment Share on other sites More sharing options...
chow choppe Posted April 25, 2008 Author Share Posted April 25, 2008 mode means? see step 3 in the image i had attached i use that option while importing to after effects thanks Link to comment Share on other sites More sharing options...
chow choppe Posted April 25, 2008 Author Share Posted April 25, 2008 those who have dealt with the passes for theri animations, please throw in some points here Thanks Link to comment Share on other sites More sharing options...
chow choppe Posted April 28, 2008 Author Share Posted April 28, 2008 STILL LOOKING FOR SOLUTION TO THAT PROBLEM PLEASE HELP tHANKS Link to comment Share on other sites More sharing options...
Nic H Posted April 28, 2008 Share Posted April 28, 2008 its a mystery Link to comment Share on other sites More sharing options...
chow choppe Posted April 30, 2008 Author Share Posted April 30, 2008 the mystery is solved thanks to kippu we have to change the matte color when importin in AE default is black but my bakground is bluish so i have to change the matte color to that works like charm Link to comment Share on other sites More sharing options...
