chow choppe Posted April 23, 2008 Share Posted April 23, 2008 need help regarding a displacement map i saw an image from arroway textures and the stone wall has a very nice displacement map in which the edges have stones and is not showing as a straight line but when i apply a displacement map to my stone wall the displacement on the faces is fine but where the faces are meeting i am getting a black edge how can i correctly make the displacement map for this so that i have stone continuity along the edges and not avertical edge. Also i face problem while making displacement for grass the grass looks awesome but border of the glass onject behaves weirdly and i see black along the edge Link to comment Share on other sites More sharing options...
BrianKitts Posted April 23, 2008 Share Posted April 23, 2008 try the search function.... this question has been asked a couple of times before http://www.cgarchitect.com/vb/28086-displacement-problem.html Link to comment Share on other sites More sharing options...
whitetr Posted April 23, 2008 Share Posted April 23, 2008 make sure "Keep Continuity: is checked in the displacement modifier. For grass, use 2D displacement. Link to comment Share on other sites More sharing options...
cdgsean Posted April 23, 2008 Share Posted April 23, 2008 In the VrayDisplacementMod keep the type to 2D, and make sure the "Shift" amount is a negative equal to 1/2 the "Amount". Link to comment Share on other sites More sharing options...
chow choppe Posted April 24, 2008 Author Share Posted April 24, 2008 thanks or the tips will try those Link to comment Share on other sites More sharing options...
Dave Oliver Posted April 28, 2008 Share Posted April 28, 2008 i have had good luck chamfering the edge of the wall a couple times. depending on your uvw mapping you still have to get the texture to line up, but on a stone wall it gives a smoother transition Link to comment Share on other sites More sharing options...
temukense Posted February 26, 2010 Share Posted February 26, 2010 I left a good answer for this problem in here: (search for post: 276778-post4) Link to comment Share on other sites More sharing options...
chow choppe Posted February 27, 2010 Author Share Posted February 27, 2010 this search directs me to this post only Link to comment Share on other sites More sharing options...
temukense Posted March 1, 2010 Share Posted March 1, 2010 Mmm as soon as i can post direct links, i will post it here. But the name of the topic was "displacement problem", search it. (or put the post code after the forum URL and ad the dot html) Link to comment Share on other sites More sharing options...
zewanil Posted October 7, 2011 Share Posted October 7, 2011 Have u finally found the trick? hello everyone ... i have been to the same problem and i have look around the site to find a good solution and i have been trougt all the topics and nothing works with my issu Link to comment Share on other sites More sharing options...
temukense Posted October 7, 2011 Share Posted October 7, 2011 I posted this solution in a thread some time ago... http://forums.cgarchitect.com/28086-displacement-problem.html#post276778 I hope it works for you. Link to comment Share on other sites More sharing options...
