tiling problem
chow choppe
hi all
i am working on a few houses for which the client wants some specific stone materials
they sent me a company pdf with stone specifications
but when i try to use those they are small in size and obviously tiling is taking place
how can i overcome this to convert them into bigger and good maps
any workaround for this
Thanks
The problem you are going to come across is repetition because the sample images dont contain many stones. You could try and find some larger images of similar stone on the net. CGtextures.com is normally quite good for stone and brick. You could also make up your own textures in photoshop using the images as reference and searching the net for the stone types but this is quite involved and will take some time. Does your client have larger images of the stone?
Images so small are always gonna tile, even with quite a bit of photoshopping.
I'd look for larger images, as mentioned CGtextures is good. Maybe by a set of stone textures from Arroway (which I can say tile perfectly straight out the box!)
