24 Cores/ 48GB Memory IKEA cabinet
I found this site through an Australian mailing list, one of the resident Linux experts added his ideas on the set-up which addresses the OS issues quite nicely...
"...1) He could have saved more money, power and time by using PXE or Etherbooting:
http://www.etherboot.org/
http://linux.duke.edu/~cegeddin/pxebooting.html
The immediate upside being that there's no power wasted on local hard
disks. The long term upside being that any changes only need to be
made once to the master image, and then simply rebooting every node
will propagate the changes automatically (rather than having to
re-image every hard disk or reconfigure every copy of the data). The
money saved on hard disks on the render nodes could be re-invested
into his NAS and network switch for more/faster storage.
I use PXE/Etherboot for thin client setups for a few retail clients of
mine. Cheap sub-$200 diskless desktops booting from a single cheap
server (or two, if you want high availability) to provide a
low-management SOE for all workstations. Extending this to render
nodes is a trivial task.
2) He also uses "plexiglass" (ie: the lay term for polycarbonate or
acrylic) to put between the motherboards. This is a rather bad idea,
as it is notorious for static buildup. I would recommend either
anti-static sheeting (say, the bags the motherboards came in), or wood
(cheap thin plywood sheets would do fine).
In this day and age, CPU cores are cheap. Multi-core desktop CPUs is
the single best thing that ever happened to the small business / one
man studio in the 3D biz. As I write this post, I see Intel Quad Core
Q6600 2.4GHz CPUs down at $270. That's less than $70 a core.
Wonderful stuff."
Your right on the price drop on the quad cores...
Wasn't me that said it, the whole message was quoting someone else (who actually knows what they're talking about - unlike myself), but yes, the prices for the Intel range are being slashed. :):):)
