Basic question..how to align gizmo to geometry
phix95
1. Set your object snap to "pivot" and "endpoint"
2. Select your object.
3. Go to the Hierarchy tab in the command panel and select "Affect Pivot Only".
4. Move the pivot/gizmo to where you want it.
(Turning the axis constraint on may help you with the alignment)
5. Exit the pivot command.
6. You're done.
Actually it was something else. I think it was accessable through a shortcut. You press a key and the x, y, and z aligned to the object instead of the environment.
Ooo I found it. It's on the top toolbar right by the scale button. There's a dropdown menu that defaults to View. You can change it there.
