Newbie question...just modeled walls
phix95
Have I forgotten anything? I'm just working on the walls now and have extruded them. I don't have many pics (front and back, and they don't even seem to match to the plans) to go on.
http://i78.photobucket.com/albums/j84/DMasek/planPersp.jpg
http://i78.photobucket.com/albums/j84/DMasek/planTop.jpg
Pic of the house:
http://i78.photobucket.com/albums/j84/DMasek/DSA199-FR-PH-CO-LG.jpg
Maybe it's a bit difficult for a beginner...
I made the walls all 10 ft tall (as the plan says to) and the doorways 7 ft. The windows are 5 ft.
Those black dots or blocks on the verandah are posts. The verandah will be open. The master bedroom will have what looks like a sliding door opening to the verandah (perfect for those that want to wake up and open their bedroom to the bright, early morning). The guest suite opposite the master bedroom looks like it has a sliding door as well.
Matt is right - you really need some elevations so you can see that 3rd dimension.
Keep pluggin' away and keep postin' WIPs! :)
Hey thanks.
The foyer is lower, I just don't know how much so I suppose I'll guess.
The elevations are what you see in the floorplan. That's all I have. This is just a project for me, not for a client or anything. I got it off the net for practice.
The veranda is open, my mistake.
As for the sliding door, do those doors go all the way to the ceiling or should I leave some wall up there?
as a Technique To get started you could draw The floor planes in 1st
just model a square and extrude 8" or whatever number works and Then
MOVE it To its correct height
Then set your Elevation To The Top of That PLANE
and you can Then model your Walls from That Height UP
This will help get everything into place fairly easily
just an idea i do This myself
Looking Good. keep it going!!!!!
I just noticed...if you look at the floorplan and then the front of the house, on the former there's an open door on each balcony; on the latter, there are skinny windows. I've modeled like the plan says which would probably mean the window extends below the balcony (?)...so what should I do?
make an executive level decision and just go for it
i cant remember Too many Times when a floor plan and elevation
(if ever) matched
also something else you might want To consider
The picture shows 9 steps UP at The front entry stair steps
and The plan only shows 7
and There are some additional 4 steps UP inside The front door at The foyer
which would mean That if There were doors That opened That They would be approx 28 inches above The outside porch area's height
which just wouldnt work for sleep walkers and small children
minor Things
just make it To be your HOUSE and make it look consistent
make it fit To whatever you want it To be (fix The inconsistencys)
The Tall (vertically) windows have door knobs so That might be
some kind of louvers or shutters which open but still are windows
it is a lot easier To model 3d roofs in autocad Than max
but just because i cant model anything in max (= just me)
looking good, keep going
hi There
i hope This is helpful (if not left me know)
here is a Front Elevation That i made from WARPing The original Foto
i finally figured out The Front Stairs steps could be 8' (maybe) and Then
kind of based a grid pattern off of That and extended it To The rest of The Foto
basic outline of an elevation, no roof lines
you probably are further along Than This by now
oops i drew The elevation with narrow Tall windows
and did The plan with The Doors as it is in The Plan
keep it going and keep us updated
Edited by vizwhiz
