david.jones Posted April 29, 2008 Share Posted April 29, 2008 Hi, not sure if this is a stupid question, or if its been answered before. When creating my irradience maps for animation (only cam animated and done on nth frame), i set up a render with the dont render final image, but when i have any interpolation in my reflections or refractions, it still does those refl/refr pre-calcs. If i cut out refractions reflections in the global switches, it doesnt calc any GI through glass, so this is no good, but how can i stop those interpolative passes? do i even need to? It just seems to extend my prepass time. Although this is not really causing any problems, i feel i may be going about this the wrong way. Thanks. Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted April 29, 2008 Share Posted April 29, 2008 That works fine, and unless its running excessively slow i wouldn't bother changing it.. if you are using reasonable Irradiance map settings, you can just adjust your reflect/refract interp min/max to be the same as your irradiance min/max Link to comment Share on other sites More sharing options...
