bully712 Posted April 30, 2008 Share Posted April 30, 2008 I finally got Vray in our office, and everything installed fine including the licensing drivers. The Dongle is also plugged into the back of my computer. When I first tried to use the Vray Render, it could not find the License. A couple of days later, I tried again and it worked. Today it doesn't work. I've contacted Chaos Group, but it's probably in the middle of the night over there. I was just wondering if anyone else was running into this problem, and if they found any solutions? I will appreciate any help. Thanks Link to comment Share on other sites More sharing options...
BrianKitts Posted April 30, 2008 Share Posted April 30, 2008 did you check that the vrlservice is running? Link to comment Share on other sites More sharing options...
bully712 Posted April 30, 2008 Author Share Posted April 30, 2008 I see it in the Windows Task Manager. Link to comment Share on other sites More sharing options...
BrianKitts Posted April 30, 2008 Share Posted April 30, 2008 do you have a free license listed in the web-based interface? unless you changed the defaults it's accessible from...... http://localhost:30304 Link to comment Share on other sites More sharing options...
bully712 Posted April 30, 2008 Author Share Posted April 30, 2008 Brian, Thanks for taking the time to respond. I saw it in the Task window, but my employee ID wasn't visible next to it. I had to manually start the license. The other day it started on its own when I logged in to my computer, so I thought it was automatic. Time to Vray. Thanks again Link to comment Share on other sites More sharing options...
