aaron-cds Posted May 1, 2008 Share Posted May 1, 2008 In previous versions of Max I've been able to select region or crop from the pull down menu (blue arrow), select the region area in the viewport then render in the vray frame buffer. In Max 2009 this pull down menu is gone. So I have to open the rendered frame window (red arrow) in max, click the edit region button, minimize the rendered frame window then hit F9 to render in the vrayframe buffer. Has anyone found a way to get the pull down menu back or avoid opening the rendered frame window? Link to comment Share on other sites More sharing options...
AJLynn Posted May 1, 2008 Share Posted May 1, 2008 It's also there in the F10 render window. Pretty annoying. I like what they've done with the frame buffer for mental ray but I don't see why they'd drop that. I think the change is in the DefaultUI in the Custom UI And Defaults. I think if you want "Classic" Max you can switch the options to Max and ModularToolbarsUI. I say "I think" because I haven't spent enough time with it to identify the changes. Link to comment Share on other sites More sharing options...
aaron-cds Posted May 1, 2008 Author Share Posted May 1, 2008 I'll give that a shot. Thanks Andrew. Link to comment Share on other sites More sharing options...
amer abidi Posted May 1, 2008 Share Posted May 1, 2008 right click on main toolbar, customize. from the drop down menu, pick the render shortcuts..find "Edit render region" and drag it to main toolbar. presto! Link to comment Share on other sites More sharing options...
aaron-cds Posted May 1, 2008 Author Share Posted May 1, 2008 ah, I was looking under the 'r's in the customize menu. I also found it in the menu when I right click on the viewport name in the upper left corner of the viewport. Link to comment Share on other sites More sharing options...
Paul Twyman Posted May 2, 2008 Share Posted May 2, 2008 Thanks for that one guys, didn't notice it in the viewport menu either, it's been annoying me all week. Link to comment Share on other sites More sharing options...
aaron-cds Posted May 2, 2008 Author Share Posted May 2, 2008 typical autodesk Link to comment Share on other sites More sharing options...
AJLynn Posted May 2, 2008 Share Posted May 2, 2008 Another one: Anybody know how to make it so "Use Real World Map Scale" is not on by default in either the maps or the UVW Map modifier? Link to comment Share on other sites More sharing options...
aaron-cds Posted May 2, 2008 Author Share Posted May 2, 2008 If you go to the custom UI and defaults switcher and change the initial settings for tool options to Max or Max.Vray the real world scale won't be activated for the material or the uvw settings. Link to comment Share on other sites More sharing options...
Ray Posted May 2, 2008 Share Posted May 2, 2008 There's also a check box in Preferences>General>Texture Coordinates that you can uncheck. Link to comment Share on other sites More sharing options...
amer abidi Posted May 3, 2008 Share Posted May 3, 2008 nice one, thanks! that one was really beginning to bother me! Link to comment Share on other sites More sharing options...
AJLynn Posted May 3, 2008 Share Posted May 3, 2008 Thanks guys. Link to comment Share on other sites More sharing options...
