al_farooq Posted May 2, 2008 Share Posted May 2, 2008 hi all, a thing is teasing me so i thought that i should ask from friends about this prob so that is ,i work in interior decoration so i create 3d rooms and then gypsum decorated ceiling some free models i merged in my scence which i down load from internet like tv , or curtains etc.normally i use mm units but the models which i get from internet normally in feet or inches.so should i merge them with their own units or should change units before merging. best of luck alfarooqdecoration makroona street jeddah Link to comment Share on other sites More sharing options...
Paul Twyman Posted May 2, 2008 Share Posted May 2, 2008 Hello, I would change the units first and make sure they are to scale, then merge Link to comment Share on other sites More sharing options...
Tay othman Posted May 2, 2008 Share Posted May 2, 2008 Hello Mohammad Well Me Prefs is to Make the Merged t Imported Object Takes the Scale From your Project that you are working on. When you start a Project Specify The Scale and When you Import or merge objects Max is enough intelligent to convert the object scale to meet your scene scale I assume that the object you've imported are to scale if you acquire objects from Internet that they are not to scale you should scale them before merging. Link to comment Share on other sites More sharing options...
