Need Help With UI Problem
danb4026
I am having a problem I cannot seem to resolve. When in Edit Poly mode ( or any edit mode) and a selection active, I cannot switch user views using my hotkeys (P, F, T, L). If I press "P" (perspective) when in edit poly mode, it makes my object Planer. I do not even have a keyboard shortcut set for "make planer".
I have to de-select everything to use my hotkeys to change views. This a real pain.
In UI, my hotkeys are set up properly, P = perspective, L = left, R = right, and f = front.
I tried loading the default UI, but that didn't fix the problem Any advice out there??
