ishpalsingh Posted May 3, 2008 Share Posted May 3, 2008 i created this custom wallniche as described in the AC11 help but it is not showing properly in the plan view how to show brick fill pattern in niche? i have changed the colour to black in the 2d symbol window but still it is appearing blue. Also that plaster layer is not extending over the niche plz help. Link to comment Share on other sites More sharing options...
ishpalsingh Posted May 3, 2008 Author Share Posted May 3, 2008 here is the file i used Link to comment Share on other sites More sharing options...
ishpalsingh Posted May 6, 2008 Author Share Posted May 6, 2008 No body here to answer? Link to comment Share on other sites More sharing options...
lucho Posted May 17, 2008 Share Posted May 17, 2008 Hi! I have a question, you have created the niche using the color blue pen??, because if you have used this pen, by defect this is the color that the niche is going to show, try to create the niche using a pen with the same color(black) of the wall, i hope this answer could help you. best regards Lucho Link to comment Share on other sites More sharing options...
lucho Posted May 17, 2008 Share Posted May 17, 2008 just another thing, try to dont use zipped files, perhaps this is the reason why the people is not answering your question, so just use attached images, good luck. Lucho Link to comment Share on other sites More sharing options...
