blowback Posted May 5, 2008 Share Posted May 5, 2008 Hello, I am getting this error message with my second pass. "error loading strip" Does anyone know what this is or how to fix it? I am rendering out a 6500 x 5200 pix image in strips and I wanted to include a reflection map and z-depth. I am rendering to exr format. The rgb pass finishes and the render just stalls. Strips not stitched back together, job not completed, error message? Link to comment Share on other sites More sharing options...
blowback Posted May 5, 2008 Author Share Posted May 5, 2008 I sort of figured it out. It won't load the strips so it can stich it back together? Why.....that I don't know...aahhh Link to comment Share on other sites More sharing options...
amer abidi Posted May 5, 2008 Share Posted May 5, 2008 probably a network path thing..happened to me once sometime back, but dont quite recall the details. Just make sure the strips are rendered to a location accessible by all machines, and not say C:\etc... Link to comment Share on other sites More sharing options...
blowback Posted May 5, 2008 Author Share Posted May 5, 2008 thanks, but it's not that. no c:\ for me .... everything seems to be in the right place.... I renedered a smaller version....no problem I am wondering if it has something to do with the size? Link to comment Share on other sites More sharing options...
amer abidi Posted May 5, 2008 Share Posted May 5, 2008 hmmmmm...interesting Link to comment Share on other sites More sharing options...
Devin Johnston Posted May 5, 2008 Share Posted May 5, 2008 Try assigning the strips to be stitched together by a machine that wasn't involved in the rendering. Link to comment Share on other sites More sharing options...
blowback Posted May 5, 2008 Author Share Posted May 5, 2008 Thanks Maxer, Can I do that if this is the only 64bit machine in the office? I tyhought there was 32 - 64 issues. I am getting soooo fustrated. I guess this leads me to the bigger question. Why is MAX craching. My settings are not that high, 1 light, some trees and cars...all proxied... I will post this elswere but....how does everyone else reneder lrg format. 6500 pix + ? What am I doing wrong? Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted May 5, 2008 Share Posted May 5, 2008 We get that a lot actually, its pretty much a memory issue involved with loading LARGE images back for stitching. Its pretty annoying. tend to just do them in photoshop when that starts to happen truthfully. Otherwise assign it to a 64bit machine, or a /3GB switched machine. Link to comment Share on other sites More sharing options...
blowback Posted May 5, 2008 Author Share Posted May 5, 2008 thats what driving me nuts....I am on a 64 bit machine.... Link to comment Share on other sites More sharing options...
moshenko Posted May 5, 2008 Share Posted May 5, 2008 I sort of figured it out. It won't load the strips so it can stich it back together? Why.....that I don't know...aahhh Are you sure it's not a naming problem? Check what Backburner is telling you that it's trying to stitch together, then compare those names with the actual strip filenames and see if something just got named incorrectly. I know that there used to be an issue with names that ended in "0000"; if you assigned "000" to the end of your file name upon submission, the strips could get appended with too many "zero's" and the stitching portion would be looking for names of files that didn't exist. Link to comment Share on other sites More sharing options...
blowback Posted May 5, 2008 Author Share Posted May 5, 2008 Are you sure it's not a naming problem? Check what Backburner is telling you that it's trying to stitch together, then compare those names with the actual strip filenames and see if something just got named incorrectly. I know that there used to be an issue with names that ended in "0000"; if you assigned "000" to the end of your file name upon submission, the strips could get appended with too many "zero's" and the stitching portion would be looking for names of files that didn't exist. thanks man, I am going to look at that. Link to comment Share on other sites More sharing options...
Conor Clancy Posted May 6, 2008 Share Posted May 6, 2008 I get this problem all the time. It's very frustrating. The only common denominator I seem to have found is if the file names are long (not including the 0000 as mentioned before) then backburner sometimes has trouble stitching them. Of course, sometimes it does stitch them... Anyway, sorry I can't be of more help. Alternatively, if you are rendering with Vray, try distributed rendering, but please don't ask me how to set this up for the first time, otherwise I might start to cry. Google it. The Vray help files in this area are less than useless. Link to comment Share on other sites More sharing options...
blowback Posted May 6, 2008 Author Share Posted May 6, 2008 Thanks, everybody, I guess watch out for those names. I just love the fact that sometimes it works....other time not so much. Link to comment Share on other sites More sharing options...
moshenko Posted May 6, 2008 Share Posted May 6, 2008 If you ever do discover that it's a naming problem, don't worry; just suspend the stitching job, rename your strips to what the job is expecting and restart the stitching job. Link to comment Share on other sites More sharing options...
